Question about JVC AM FM CD DET FACE CAR STEREO
Ipod connection i had a jvc kdg 340 installed. the adapter for the ipod connection has to be plugged in the rear of unit. how do i remove unit to plug in ipod adapter?
  • 265 Answers
If you got keys that came with it just slide these down the side, if not just take of the face plate and slide to flat headed screw drivers down the side. it wont damage it.
please rate
Posted on Feb 21, 2009
My car radio unit a ' JVC, KDG 635' how can i connect my ipod to it to play music?
in the front there might be a place for a plug from your ipod or in the back of stereo theres two wires coming out , buy a cable that goes from one into two in the back of your stere
Dec 15, 2010 | Car Audio & Video
Have a jvc head unit, where do I connect the steering wheel audio control wire? JVC KD R310, 2002 Nissan Maxima.
Do you have an adapter that converts the Nissan controls for the JVC? Typically this piece is specific to the car and required as a separate item. If you do have this piece, then typically one of the plugs you removed from the factory stereo but aren't currently using will plug into the control adapter unit and then it will have an output wire to connect to your JVC.
Aug 09, 2010 | Car Audio & Video
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
Connecting an Ipod to JVC TH-M45 System
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
Apr 20, 2009 | JVC TH-M45 System
Remote wire location
Hi and welcome to FixYa,
On the JVC, the blue wire is intended for a motorized or power antenna and therefore would only work when the JVC KDG-821 is set to tuner (AM or FM) mode. The external amplifier trigger from the JVC unit is blue/white. This should connect to the trigger / remote terminal of the amplifier.
Good luck and thank you for using FixYa.
Apr 09, 2009 | JVC Car Audio & Video
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Mar 16, 2009 | JVC KD-LH810 CD Player
Manual for a car radio
Your best bet would be to look on JVC.com I bought a JVC head unit from a friend, and i printed out a manual on the jvc website, and it was free
Nov 19, 2008 | JVC Car Audio & Video
JVC KDG 340 Car stero
SOUNDS SETTINGS....OPRIME EL BOTON Q DICE EQ...EN LA PARTE SUPERIOR DERECHA....Y ADJUST BASS....PRIMERO OPRIMES EQ.....SELECCIONAS USER..Y LUEGO OPRIMES LOS BOTONES DE DIRECCION HACIA ARRIBA Y HACIA ABAJO..Y AHI SE LO PUEDES AJUSTAR
angel_lk2@hotmail.com
Mar 17, 2008 | Audio Players & Recorders
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
103 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
