Question about Casio Watches
Bracelet too big. How to adjust it? - Casio Watches
    President:
  • 2,976 Answers
Push the pins out of the links with a pin ir small psper clip. Some have flaps that need to be unbent so you can remove the 'U' shaped link holders. It all depends on the style on the links.
Posted on Feb 21, 2009
Adjust jubilee bracelet
You bend it , literally take hold of the inside arch and bend it with your hands in not out this shortens the , the length and helps it close .
Oct 02, 2014 | Rolex Lady Datejust 179173SRJ Watch for...
How do i adjust the band on my invicta 4898 is to big i need it to be shorter please help
To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
After removing one links, connect the two links from two sides by placing the bracelet pin back into the hole and push it to the other end.
Feb 16, 2011 | Watches
Brasalet unlocks all the time by inself ,I need new brasalet or lock replaced, how I get the parts.
mcdevito75 here, Many times the Bracelet clasp can be adjusted. Look for a small watch repair shop in your area. approx, fix price, $10.00--$20.00 chaeper than new, if bracelet can be adjusted.
Jul 18, 2010 | Wittnauer 12E08 Wrist Watch
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Self-adjustable bracelet watch
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Need instructions for resizing a Link Tag/Heuer Watch bracelet
Hello! I just went through the same thing. If you got the watch new, you can look in the box to find "mini" or "half" links included with the watch. There is no fine adjustment on the Link, but you can replace the larger links with the "mini" links to get the size closer. They are not quite half size, more like 65% of a regular link. So if you add one "mini" link and the watch is too big, you can then replace a regular link with a "mini" link to keep adjusting the size. I went to a dealer (Jared does this, as does Torneau...you talked to the wrong person) and it took about 5 minutes and was $15.
Hope this helps.
Jul 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Dec 08, 2007 | Watches
Watches Logo
967 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
