SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
SOURCE: My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
