Question about Kenmore Washing Machines
Second Rinse Switch Broken
I believe the second rinse switch is broken because when switched to ''one rinse'' it still second rinses load. I ordered part W10168257. Can you tell me how to replace this part?
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Spin not working on final cycle
no rinse at all or just at second final cycle? if so its either bad clutch, tranny, motor coupler, belt broken, or even door switch out? depending on either a belt or direct drive motor
Dec 19, 2014 | Washing Machines
Model 9156200 top loading washing machine
the lid switch may be loose or broken it happens to me it was washing but never rinse i found out that it was a loose switch this switch prevents the rinse cycle from working with the lid open because of the high speed rinse ,some machines dont work at all, a loose switch makes the machine think the lid is open even if it is closed.good luck.
Apr 16, 2014 | Kenmore Washing Machines
Whirlpool washing machine will wash but will stop and not drain or rinse
Hi!!
In order for the high speed spinning (rinse) cycle to begin, the lid must be shut. If your unit is top load, the problem is more likely the lid switch. or the tab on the lid that activates the switch is broken. If the tab is OK, disconnect unit from power outlet, remove back panel and trace the two wires going to the switch, once located, use a piece of wire to jump the two together, reconnect unit to power outlet and set the knob to rinse cycle, if unit works, replace switch.
Good Luck!!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 16, 2011 | Whirlpool Washing Machines
Whirlpool washer won't rinse/spin
make sure first it isn't the lid switch. As the lid closes, a pin in the lid usually pokes into a panel/hole and closes the switch. If the switch has been smashed by an unbalanced load, it often cannot let the machine spin for safety. If you cannot tell if the switch was damaged, remove the case. You'll likely see broken plastic on switch lever.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Machine wash ,but will not rinse or spin
You have a broken lid switch. Assuming you have the same style washer. The switch is #11,
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Still confused ...
the timer should be moving by itself to rinse and spin and than finish the cycle
If your timer stop at rinse cycle you gonna need a lid switch.
Problaby your lid switch is broken
May 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washer goes through extra rinse every time
it showes that the machine has a second rinse switch on the console set it to no second rinse
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
