Question about GE 5.8 Cu. Ft. Extra-Large Capacity Electric Dryer
Want to vent dryer from bottom. How do I remove the bottom/side
I have a 2-cycle electric dryer from GE. It has a vent duct cutout in the bottom, but I can't remove the bottom or side panel to see what I need to be able to vent it from bottom. Please advise how to remove panels.
  • GE Master
  • 3,361 Answers
Unplug the dryer.
Open the dryer door.
Get on your knees and look up.
You will see 2 phillips head screws that must be removed from inside the door cavity.
Remove these screws, then the top of the dryer.
Then remove 2 screws on the right and left inside of the dryer.
Unhook the door wires and remove the front panel.
Posted on Feb 21, 2009
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Battery fell in lint area of kenmore dryer.
next time send model number,open the door,look around the opening where you put the clothes in and you'll see the number,might start with 110,is the filter on top of dryer?if so unplug the dryer,take out the filter and remove the 2 screws on top where you pulled the filter out of.now go the back of dryer,take off the vent line and remove all the 1/4 inch screws in the back panel,on the left side you'll see a metal duct that the filter slides down into,take off the 4 screws most of the time they're 5/16 inch screws,remove the duct or slide it to the right and you'll see the blower wheel,you should find the battery there or in the bottom of the duct,vac that duct out while you have it off and clean out the vent line,if the filter is inside take off the bottom panel,you'll see the duct in the middle,take out the filter and remove the screws and you'll see the battery,good luck
Jan 22, 2010 | Kenmore 63012 Electric Dryer
Does maytag make an electric dryer with bottom vent?
you want to vent of of the base of the dryer, directly down? None of the maytag/whirlpool line can handle this anymore. Only side vent options. GE may still be able to bottom vent. no dryer is really made for it out of the factory but some can be converted to it with a kit. usually if they can there will be a knock out panel for the duct in that place. GEs heater is on back wall making more room on the base for this kind of thing.
Jul 11, 2009 | LG DLG2525S Electric Dryer
Kenmore Electric Dryer Can't replace heating unit
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Feb 09, 2009 | Kenmore 659 Electric Dryer
How do i get to the heating element for a kenmore dryer # 11062972102
Before accessing the heating element,:it very seldom fails
The most common cause of no heat to an otherwise functioning dryer is failure of the thermal cutout.
As well as the electric line fuses in the circuit there are devices that look like this 7883694.jpg or this c594de5.jpg screwed to the exhaust air duct or fan housing with wires to the terminals, inside the dryer. If there is a lint blockage in the duct or fan or outside vent hood, the air temperature rises and melts out this thermal cutout (also thermal fuse, heat protector, heat cutout & any other names different makers use) before causing a fire.
Test with an ohmmeter or battery and lamp bulb, conducts good, no conducts fail-replace.
Despite the number of models of dryer there are only a few thermal fuses, and the local parts guy WILL have the blown one on the shelf, as GE if not as kenmor part.
Whil the dryer case is opened is a good time to vacuum out the exhaust vents, fan impeller, and vent hood. ounce of prevention and all that
Sep 06, 2008 | Dryers
No heat
As well as the electric line fuses in the circuit there are devices that look like this 13889aa.jpg or this 284f4e0.jpg screwed to the exhaust air duct with wires to the terminals
, inside the dryer. If there is a lint blockage in the duct or fan or outside vent hood, the air tempoerature rises and melts out this thermal cutout (also thermal fuse, heat protector, heat cutout & any other names different makers use) before causing a fire.
Despite the number of models of dryer there are only a few thermal fuses, and the local parts guy WILL have the blown one on the shelf, as GE if not as roper part.
Jul 26, 2008 | Roper REX4634KQ Electric Dryer
Asko T701 Runs for full cycle but does not dry
thermal cuttouts(thermal fuse or half a dozen other names for the same thing) on the exhaust duct look like this 088c0f1.jpg or this 89f91e6.jpg, the high temp one is blown.
locate and test with ohmmeter or bulb and battery
replace, not a repairable item, but inexpensive,
there are very few cutouts common to many dryer models
the local parts guy will have one to suit even if marked frigidaire or ge
while the dryer is open is a good time to de-lint the fan and exhaust ducting to the outside wall to prevent recurrence
Jun 25, 2008 | Asko T701 Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
GE 5.8 Cu. Ft. Extra-Large Capacity Electric Dryer Logo
1,187 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
