Question about Sharp DT-300 Multimedia Projector
Having problem with focus, cant even read the menu sharp dt300
just bought a sharp dt300, picture is visable, but having trouble making it clear, played with the zoom and focus features, but still running into the same problems
Try cleaning the color wheel with rubbing alchol and a q-tip
Posted on Sep 11, 2013
Sharp TV slightly out of focus
so not focus on out side please focus on write side http://specialneedsplanning.net/
Mar 18, 2013 | Televison & Video
Need instruction manual for outlet timer#59732 Model#DT300 125v/60Hz 8.3amp/1000watt resistive. Only other #s isee 227259
Open following links for possible DT300 manual:
I don't see load rating in manual, but 1000Watt would be typical for timer with 2-prong outlet.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
If manual is not correct:
Other folks have asked for DT300 manual, but didn't like provided manual.
Timers can have many different numbers, and different timers can go by same number:
1) Add a comment with link to in-focus photo of timer posted on Flickr, for possible identification.
2) Open following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Aug 07, 2011 | Woods 17321 Outdoor Power Strip Timer with...
Tasco telescope[46-114500]cannot see anything through lens.bought
THE protective cover is the FRONT of the telescope!!!
The focuser is on the front like the picture above. TURN the scope around -- you have it pointing at the ground right now!
Read my TIPS on my profile page. And read this and look at the pictures:
http://www.texasastro.org/telescope.php
Jan 15, 2010 | Tasco Galaxsee® 46-114500 (500 x 114mm)...
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
How do I adjust the HD quality for a crisper picture? I have tried Magic Focus, but need to know where the sharpness or contrast can be tweeked .
The magic focus function is to electronically align the red, green and blue beams. So all it can cure is colored ghosts. The contrast, brightness and sharpness adjustments are in the customer menu settings. With the remote just push menu and select video or picture adjustments. Those adjustments are in there.
Jun 11, 2009 | Hitachi 57F500 57" Rear Projection...
Blurry picture
no it is not hopeless! if you want to do this procedure I can help you adjust the main screen focus inside the television on the FLYBACK TRANSFORMER but you will need to take it apart unless there are access holes in the back for the adjustment.
Oct 13, 2008 | RCA F32450 32" TV
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Sharp 20f640 focus problems
At the rear of the tv there may be two controls on the right hand side marked "screen" and "focus".If the set is newer,you will have to remove the cover and look to your right.You will see a dark object with a black or red wire coming out of it's top.That is your flyback transformer.On this you will find these two controls.Adjust your focus with the one so marked.Be careful to only adjust this control while you watch your picture clear.PROMPLY put the cover back.
Feb 10, 2008 | Sharp 20F640 20" TV
Black screen...no color
On the back of the set, look for 2 controls labeled focus and screen. If the TV is working but you cannot see the picture, try turning the screen control up little by little and the brightness should come back. If this works then make sure the focus control is set so that the picture is nice and sharp.
Jun 16, 2007 | RCA F19207BC TV
Picture brarred, focus responding but cant improve picture quality
did u try adjusting the focus knob in the flyback transformer? this device is connected to the anode of the picture tube which produces the high voltage so be very careful of adjusting it. dont touch the wire linking to the tube. thats approximately more than 21,ooo volts dc! good luck!
Jan 17, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Sharp DT-300 Multimedia Projector Logo
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
