Question about LG WM-2277HW Front Load Washer
Start button is depressed and won't start the cycle
I am attempting to access the control panel on the front of the washing machine. What do I have to do to get at the internal components of the control panel? The power has been disconnected as well as the water lines.
  • 706 Answers
Use this link to the service manual, it elaborates on how to access various components within your washer..
http://136.166.4.200/contents/Laundry/WM2277.htm
Hope this helps you..
Regards,
Rick
Posted on Feb 22, 2009
Push to start button wont turn on washer, control lock is off
If disconnecting power and then re-applying it resolves the problem you have a bad relay on the control panel and it needs to be replaced to actually resolve the problem. Note that there are two control boards right there in the front. Here is a diagram to use so you can get a visual of what I'm talking about.
http://www.partselect.com/ModelFrames.aspx?ModelID=615234&ModelNum=GHW9150PW0&mfgModelNum=&ManufactureID=3&Selected=B0DCARYP&Position=1&mfg=Whirlpool&Type=Washing-Machine&Mark=1
If all the functions are working as set when the machine is able to start, then more than likely the first board is the bad one, but to honestly know you'll need the machine in the state where it won't start, with the top off and access to the boards. With a volt meter you'll need to check to see if the assigned voltage is going from the first to second board. There is a wiring schematic in the machine somewhere that will give you all the specs on that.
Jun 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My Bosch WFL 2060 has a new motor and a new electronic panel. It fills but then it won"t start the wash cycle. Any help ou there on this computer machine?
Hi welcome to Fixya. Replacing the motor is pretty straight forward however, the issue with simply replacing those controls is that they do not come configured. This must be done before installing and operating the control. It cannot be done once installed and continuous attempts to use it could cause damage to the control. I can send you a guide on "how to" but I'm presently out and do not access since I'm using my iphone. I'm currently in the process of setting up a windows live account that will allow people to access these things much easier, but I'm not there yet. Stay tuned ha ha ! Let me know if you'd like further assistance. macmarkus :)
Jul 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Elite won't start
The control panel (touch panel) is faulty - and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA34 washing machine
Remove top cover, 2 screws are hidden behind 2 plastic covers at front of lid, push the lid back to remove , undo the screws that hold the dispenser, and slide the console panel to the right, then you can access the control board and reset the button,
Sep 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Machine stops mid cycle
Replace your control button(Start button).
Jul 22, 2008 | Maytag EPIC MFW9700S Front Load Washer
LG WM-2277HW Front Load Washer Logo
163 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
