Question about Fisher and Paykel GWL11 Top Load Washer
Lint filter I realize there is not a typical lint filter on the GWL-11. But, is there one within the machine? I've used this machine for a number of years and now in the last 6 months it seems to be filling up with lint in the pump. Is there a "chopper" like in a modern dishwasher? How does it deal with lint, a natural by-product of clothes washing? Thanks.
  • bobdog296 Feb 28, 2009
    I'll give 'er a whirl tomorrow. I've been able to find a parts list/diagram at and that has been very useful as well. Thanks for the help.
  • 145 Answers
Hi Bob... You probably have a buildup of crud in the outer tub itself, or perhaps someone washed a rug and the backin has come off and is all in the outer tub and little by litter it is cloggin up the water pump. I would suggest that you pull the inner basket out of the machine and do a good cleaning of the machine. It's rather easy to remove that inner basket- you only need a phillips screw driver!
1. Pop out the two plastic white caps near the front/top (under the washer lid but on the top of the washer) and remove each screw.
2. Remove the agitator by popping the fabric softener cap out and simply reaching down in the center and unscrewing the white plastic "tee" nut that secures it to the agitator shaft and lift the agitator up and out.
3. Lift the machine's top up (it lifts up just like the lid does)
4. Unsnap the "tub collar" from the washer tub, (requires no tools!)
5. Grab ahold of that entire inner basket and lift it right up and out of the machine. (you may want a helper to hold the machine top back for you)
Now with that basket out, you can see what you need to do as far as any kind of build-up. You can wipe clean the inner plastic tub and remove any lint/rug backing/crud you see, and you can take that basket and clean it up in a laundry tub, of it is warmer where you live, take it outside and spray it down with a garden hose. The underside is probably going to filthy. The outer side of the inner tub is almost like a cheese grater, it might have some lint snagged in the holes. Just spray it down and clean everything up. Put it back together and you're good to go again.
It takes me about 10 minutes tops to pull the inner basket. Fisher Paykel's are very easy to work on.
Posted on Feb 28, 2009
Hello - I will be happy to assist you. However, in order to provide the information you are requesting, may I please have your model number. Typically, the lint filter is located on the lower front as you open the door.
Jan 02, 2013 | Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 started leaking
The pump is most likely leaking, if you need a part check with your dealer or email me and I can ship it out.
Feb 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
My 10 year old kitchenaid dryer
if its not producing lint then more than likely that it has a hole in a inner pipe and the lint is going inside your drum take the back off with the machine un-plugged and check if lint is inside then clear it out has this can set afire then find were it is coming from u can do this 2ways look for the hole or plug back in and start it if u will notice were it is coming from within a few minutes
Aug 22, 2007 | KitchenAid KAWS850L Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
472 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
