Question about IBM Thinkpad I1400 2621 Planar TV (10L1537) Motherboard
Change of CMOS battery in IBM Thinkpad 1400 2621
How do I find the CMOS battery in my old IBM Thinkpad 1400 2621 in order to replace it?
  • henrikboge1 Mar 22, 2009
    Thanks a lot !!!!
    Now it works
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Posted on Mar 12, 2009
  • akgeeks Mar 12, 2009
    Small note, there are actually **6** screws holding the silver plate, one is a tiny silver screw at the upper left corner of the plate, near the 'box' pattern of the 4 screws holding the video chip heatsink in place. While putting it back together I realized I had missed it.
  • 2,653 Answers
Those are a pain to replace, especially on the ibm's.
Every IBM I've taken apart I've had to rip through everything to get to it. Start with the easy locations first like underneath the memory panels, etc on the bottom of the laptop, if not there check under the keyboard and if not there then it's sometimes near the might be able to find a guide somewhere online but honestly the best thing to do is to just carefully crack that bad boy open and poke around.
Best of luck!
Posted on Feb 21, 2009
I need to change the CMOS battery on my IBM Thinkpad Type 2658 Is there anywhere I can go to see how to do it. There was a link on another site but I think it is very old and it didnt work
For change the CMOS battery in you laptop visit""this link and get the solution.
If my solution make you happy then give me the four thumb
Jun 28, 2011 | IBM ThinkPad R32 2658 Notebook
I keep getting ;messages saying I need to replace the internal battery 601/ Can I buy that online?
This sounds like the error you would get on an IBM thinkpad or Lenovo laptop.
There are third party sources for these all over the place.
As an example, I own an IBM thinkpad model A20M.
If I google a20m CMOS battery, I am sure to find a plethora of sources online.
Being Canadian, I go to Ever Corperation at for any replacement batteries I need.
Make sure when you order your battery that you aren't ordering the main battery pack, and are indeed ordering the CMOS battery.
Installation instructions should arrive with the battery.
Jun 04, 2011 | Computers & Internet
My ibm thinkpad t41 turns off after sometime when i turn it show cmos checksum bad
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
How do I replace the CMOS battery in IBM A31 laptop?
here is the link to the hardware maintenance manual .. Go to page 75 and this will give you step by step instructions
Feb 10, 2010 | IBM ThinkPad A31 Notebook
My R40 Thinkpad loses the system date & time after being shut down for a while. However it does not lose it if only shut down for a few minutes. Any ideas please?
you need to change your cmos cell on motherbord circuit for that open back side cover and then you can see cmos cell on motherbord circuit.Change it pur chase new cmos cell.
Your old cmos cell has not enough waltage so your bios settings are not saved when you turn off the power.
Jul 16, 2009 | IBM ThinkPad R40 2722 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Black Screen at boot up
May be the CMOS battery you replaced is not compatible or firmly placed.
Check if you can enter in BIOS and change setting for Power option.
Generally, F2 , ESC or DEL key used to get in BIOS.
Also you may try Tapping F8 key during startup of PC to get in Safe Mode, and then Check for Event viewer entries if any red cross entries and error found in System and Application.
For more geniune Fix to Problem, please ask to EKSE (Guru), as he is more experienced and well equipped to solve such problems.
In any case let me know the status, and do not vote till you get the solution.
Oct 31, 2008 | IBM ThinkPad 600X Notebook
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
Computers & Internet Logo
3,804 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
