Question about AOpen P4/2.4 40GB 512MB XPP (SQ1003892ST88076) PC Desktop
Microsoft XP STOP OXOOOOOO7E OXCOOOOOO5 OXF78DA208 OXF78D9F08 - PCI.SYS add f748eobf base at F7487000,Datestamp 3b7d855c
  • 31 Answers
If you didn't yet then upgrade to SP2.
Update drivers for all hardware, in most cases this is a driver conflict.
If that didn't solve the problem then scan for viruses with AVG.
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?cdlPid=11006019
Scan for malware with Anti Malware.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?cdlPid=11004434
Scan for broken registry entires with Registry Mechanic.
http://www.download.com/Registry-Mechanic/3000-2094_4-10190447.html
Let all 3 software repair/remove the errs they find.
If the problem is still not solved then reseat the memory stick to another slot, since 7E with nt status code c0000005 (access violation) could be caused by faulty RAM. Clean the dust inside the PC.
If it still crashes, downclock the RAM.
If it does not resolve the problem, replace the RAM.
Posted on Feb 21, 2009
When loading xp a blue screen came up with the following message code: 0x0000005, 0xF76130BF, 0xF7A5F208, 0xF7A5EF08, PCI.SYS. ADDRESS F76130BF BASE AT F760C000, DATESTAMP 3B7D855C. Can anyone help and...
Uh...you have the "blue screen of death." This is the nickname for a massive hardware or software failure on windows. Go to a repair center.
Feb 11, 2011 | Intel Motherboard
I'm trying to install a windows xp on a new seagate 750GB Hard Drive and get this A problem has been detected and windowws has been shut down to prevent damage to your conputer. Technical Info. ***Stop...
normally this error occerd when there is any bad sector in your harddriver or problem in motherboard components.
first of all chek that is there any component like cpu or motherboard is overheating.
then check the fan speed of your motherboard.
clean the complete mother board with vacumecleaner and if components are not overheathing then restart and if fan speed is nomal then try to reinstall your os.
2nd option check your ram..
May 17, 2010 | Computers & Internet
I have a laptop with windows xp home on one partition and windows 2000 on the other. I want to remove windows 2000 and instal a fresh copy of xp as the one that is on it is giving me the activation error...
If you dont have any files on your computer that you dont want to loose, you can do a full format,
reebooting your computer with the XP cd in its tray.
If your BIOS settings are right you should get the
option something like: "install os from disk"
push any button.
then you able to access the installation meny,
there you can choose to delete all partitions,
enabling you to install XP to just one partition of your disk.
Hope this helped,if it did, please vote!
May 16, 2010 | Microsoft Computers & Internet
I have installed a P5KPL-AM IN/GB Motherboard from which it will not install Windows XP from CD. It Boots up normally then stops with a message "A problem has been detected and Windows has been shut down...
this could be a wealth of issues. check to see if all the hardware is compatible with the new mobo. if you're not sure try disconnecting different bits of hardware to see if you can get past the system error.
go into the bios and make sure the cd drive is listed as the first device in boot priority
Feb 25, 2010 | Computers & Internet
Blue screen when trying to install o/s from cd.
Not a lot of help here, other than to suggest it's caused by some hardware or driver conflict, but see this ms article. You could try then, this link to stop error codes, and these MS links here and here
I suggest you google "0X0000007E + pci.sys" and read the forums to see if someone out there has a solution...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Gateway GT5220 PC Desktop
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Blue Screen
Try disabling PCI-Express in BIOS setup
Feb 16, 2009 | ASUS Eee PC 1000H Laptop
Hp530 software from vista to xp
hi there,
it seems that this particular message can be related to problems with drivers being loaded. so i guest is u are using a xp cd with SP1 try a copy of XP Pro SP2 included .... also check out the ram on your system... ddat could be a bit of a problem also....and last ... in Bios change hdd from AHCI to IDE mode ... xp has a bit of a trouble seeing sata drive
Apr 08, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
2,692 people viewed this question
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
