Question about LG DLE5977 Stainless Steel Electric Dryer
LG TROMM DRYER DLE5977 Burning Smell
2005 LG TROMM has been working great till now. put in a load of clothes then noticed a burning smell almost plastic like. no smell when its on air dry. cleaned the lint catch and the vent in the back is clear. Any Ideas what this might be?
thank you in advance.
  • Anonymous Apr 21, 2009
    I am having the same problem with burning smell.
  • 3 Answers
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
Lg tromm gas dryer burning smell shuts off
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
Smell something burning when dryer on and noticed brown stuff on back of dryer that has holes on it where I think heat comes from. How do I fix this?
a drum wheel make be frozen causing it to smell and have black residue from the rubber.
here is a video of how to check and disassemble
http://www.youtube.com/watch?v=Sy_ZK5f-WS8
Aug 09, 2013 | LG DLE5977 Stainless Steel Electric Dryer
I have an LG gas dryer, lately when the dryer has finished my clothes has a burning smell to them. I recently painted and noticed the smell at that time. Though the paint smell is gone the burnt smell has...
Mark, My name is Hal and having trouble understanding where you painted. Did you paint the inside of the drum? Or did you paint the house interior?
If you painted the inside of the drum did you use a high temperature paint? If not, that could be your problem since the dryer does get very hot inside and it could be melting your paint.
Aug 06, 2011 | LG DLG5988 Gas Dryer
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Burnt smell on dryer
Hello fyffeta,
3 or 4 prong power should have no bearing on the dryer performance..3 prong provides 2 power feed lines and a neutral versus a 4 prong system that provides the same two power feeds, a neutral and a ground.. so performance wise.. you should not expect any. The fact that it sounds louder is subjective and may be a function of the move. whereby something inside the dryer shifted a little when transporting it.. or the accoustics of the new room. If you smell something burning then I would check the exaust duct system for any material and/or restrictions.. It is possible that by moving your dryer..some lint, fibers from clothes or even human hair may have been dislodged and found there way into the blower/heater region and are burning off.. With the plug disconnected..Make sure your power cable terminations at the dryer are all snug. a loose connection there is dangerous and is resistive ( which means it will get hot) and in some cases.. could cause a fire so check that carefully..
In all probability..you may just have some lint or something that shifted during the move and is burning away...
Good Luck
Rick
Jan 03, 2009 | LG DLE5977 Stainless Steel Electric Dryer
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE5977 Stainless Steel Electric Dryer Logo
2,376 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
