Question about iLO DVDR05 DVD Recorder
DVDR05 Power Supply Board: No output, top blown
DVDR05 Power Supply Board: No output, top blown off IC1, STR(I think)next to Transformer and D5 is open, D3(regulater I think) is open. Need relacement parts and circuit diagram. Anyone Please. Mel Brooks, k5djb@att.net. Thank you.
  • kenwhite73 Mar 09, 2009
    Mine makes noises in the same area then shuts off problems with that power supply board may be common. Mine worked wonderful for months now its just a paper weight.
    Don't they stand behind their products, It would be a good idea to supply replacement parts.
    Problem Solver:
Try a small sledge hammer for some up close and personal work.
Posted on Mar 01, 2009
Lg ultra slim TV supply STR 6554 ,110 volt drop in one second when we on the tv
Is the power source/transformer
output to spec
looks a bit past it in your photo
resistors drop ......capacitors increase
look for leaks or printed board burns42045576-892f-42e6-be9f-ea2f910b1692.jpg
Mar 30, 2017 | LG Televison & Video
Sony str-av1020 reciver Power supply transformer burned!
http://www.sony.owner-manuals.com/STRAV1020-service-manual-SONY.html
Aug 19, 2016 | Sony Audio Players & Recorders
Model DP170MW8B Moved player now it won't power on at all.
Check power supply. Check the fuse. If it isn't blown, check all components within this board, including the IC regulators (however many this model uses for PSU - should be marked IC1 or similar reference) - check for short-circuit/open-circuit/leakage. Also check all of the electrolytic capacitors - some may have leaked. Check resistors diodes etc. for shorts, leakage or open circuit. Also go over the entire board for dry solder joints too - just to be sure, and re-solder any suspect joints. If the power supply uses a transformer, check this for open windings, particularly on its primary side (the side facing the power cord), most switchmode power supplies use a chopper transformer which can sometimes fail.
If you are in any doubt, you can always get a second opinion. It may or may not incur a fee. But either way, patience plays an important part in this. You should not need to buy a new player - fingers crossed, that it's something simple.
Feb 12, 2011 | Magnavox DP170MW8B DVD Player
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Thanks,
Dan
Oct 23, 2009 | Audio Players & Recorders
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
AC power supply problem Sony STR-DE935
The part is available from tritronicsinc.com. It costs $8.74. Just enter the part # and it will come up. Good Luck!! Please rate this solution!! Thanks!
barneyluc
Oct 05, 2008 | Sony STR-DE935
Ilo dvdr05 needs power supply
Most electronic components are available at any large parts warehouse, except maybe the power transformer, and other indigenous parts. What part of the power supply do you need?...accordianman
Mar 05, 2008 | iLO DVDR05 DVD Recorder
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
iLO DVDR05 DVD Recorder Logo
236 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
