Question about Lexmark P4350 All-In-One InkJet Printer
I nees a setup sheet to re-install my P4350
I am re-installing my P4350 and need a setup sheet to guide me through the process.
From the desktop,click start programs lexmark 4300 series uninstall. follow the instructions on screen to remove the printer software.restart the computer.click cancel on any add new hardware screens insert the installation cd
IF the software installation screen does not appear. from the desktop double click my computer in windows xp click start to access the MY Computer icon.Double click the cd rom drive icon. If nessessary,double click SETUP ExE .when the software installation screen appears, click install or install now Follow the instructions on the computer screen to complete the installation.
Posted on Mar 01, 2009
Since conecting my Lexmark P4350 to a different pc it is sometimes only printing half a page and sometimes the print is smudged. can you suggest anything.
Make sure that the printer driver is properly installed. Please visit the Lexmark website to download and install the Lexmark P4350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the install process is complete, try to print again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark P4350 All-In-One InkJet Printer
My computor will not recoginese my lexmark printer model p4350 i think i may nee anew c/d as my original is a bit scratched can i buy one and if so where
There are Lexmark P4350 drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/9yASdX. Click on the Microsoft or Macintosh dropdown found below the page to choose the version of the operating system of your computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 14, 2010 | Lexmark P4350 All-In-One InkJet Printer
I have a Lemark p4350 and I cannot figure out how to scan pictures on to the computer? I have NO idea what I am doing?
Hello. You will need to install the scan software in your computer first. The software can found in the installation cd that came with your printer. Insert the installation cd in your computer and install the software. Just follow the instructions carefully. The software enables the computer to communicate with the printer and vice versa. Without it installed, you won't be able to print/scan from your computer. There is also a link to the Lexmark website where you can download the User Guide. It will give you detailed instructions on how to scan and do other features the printer can do. Just click on this link: http://bit.ly/b6359P . Click on Publications tab found at the center of the page. Download the PDF file User Guide. Hope this helps. Good luck!
Mar 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
Installation instructions for 6100 to laptop required
Here is the Setup Sheet:
Lexmark 6100 Series Setup
And...the User Guide:
6100 Series User Guide
Here is the link to download drivers if needed:
6100 Support
Click on the Downloads tab. Select the correct one for your Opeating System.
Sep 08, 2009 | HP Pavilion Media Center a1330n - AMD...
How do I use the scanner?
Here is the link you need :).
http://www.lexmark.com/publications/eng/7100/index.html
There are 2 Guides which are :
Setup Sheet
Setting up the printer, attaching cables, installing print cartridges, and installing software
 User's Guide for Windows
Loading paper, changing the printer settings, maintaining your printer and its cartridges, and solving problems
Mixtrixx
Dec 01, 2008 | Lexmark X7170 All-In-One InkJet Printer
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
Lexmark P4350 All-In-One InkJet Printer: needing installation disc
Please do not worry, u can download installation software from this link :
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+P4350
Mar 14, 2008 | Lexmark P4350 All-In-One InkJet Printer
Cant load paper into my printer
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to loading the paper    . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Please try below steps if you want to know how to load paper in to the Feeder.:
Important: When loading paper into the feeder, make sure you are using separated (i.e., cut) sheets of paper. Banner paper that is connected end-to-end should not be used unless you are specifically printing a banner.
To load separated sheets of paper:
  1. Obtain a fresh stack of paper.
  2. Separate the paper by bending it back and forth in an "S" shape before loading it into the printer.
  3. Place the paper against the right side of the sheet feeder, with the print side facing you.
  4. Gently insert the paper into the feeder. Do not  force the paper down into the printer.
  5. Squeeze the release tab and the paper guide together, and slide the paper guide to the edge of the paper.
Humid conditions may cause some sheets of paper to stick together.
If the issue still persists,  then I recommend you to look in to USER MANUAL that is provided along with Printer for instructions on loading Paper.
Well, for your convienience I'll provide you with steps that helps to access USER MANUAL.................
Steps are :
  • If the Lexmark P4300 software is already installed in Windows:
    1.  Go to Start, (All) Programs, and point to Lexmark P4300 Series.
    2.  Select User's Guide.
  • If you have not yet installed the Lexmark P4300 software, you can find the User's Guide on the installation CD.  Do the following:
    1.  Insert the CD into the CD-ROM drive. The Lexmark installation screen should appear.
      • If the screen does not appear, open My Computer and double-click on the 4300 Series icon.
    2.  Click on the ?  icon to the left of View User's Guide (including setup troubleshooting).  You will be asked whether you would prefer to save the User's Guide to the desktop and view it from there (Yes), or to view it from the CD (No).
    3.  Select the option you prefer.
  • This should resolve the issue for you.
     If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
    Bye.
    Oct 18, 2007 | Lexmark P4350 All-In-One InkJet Printer
    Lexmark P4350 All-In-One InkJet Printer Logo
    116 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
