Question about kawasaki Full Suspension Mountain Bike Men
BMX ball barings
My friend said he will grease it but later he said he dont know how to puth them bacl now i cant fic the he took all the little balss out please help
  • darkejoe Feb 28, 2009
    clicking noise coming from pedals apparently its coming from the pedals maybe broken i dont know can u help
    Problem Solver:
  • 7 Answers
Put a thin layer of grease in the bearing race/concave part where they go. If they have a retainer pop each ball back into the retainer, test fit all before grease goes in. Make sure that it all fits smoothly, and snug not too tight. If the balls themself are out of the retainer they will pop back in fairly easy and the retainer can also be bent back into place to keep the ball bearings in place.
Posted on Jul 29, 2009
Creaking sounds coming from front right suspension ?? what could it be??? And how much would it cost to fix
Could even be a loose body mount, or maybe the spring wore through the plastic/rubber shield at the bottom. Could also be the top of the strut, that part can be replaced by itself.
Mar 02, 2017 | Chrysler Town & Country Cars & Trucks
So my Dynacraft Next turbo bicycle crank arms and pedals were wobbling and found out the issue was a bent bearing.So instead of taking it apart,we decided to hammer the bent bearing back into the crank...
the little balls are the bearings, ie: ball bearings, so they are the size, take them to a bike shop and get a replacement kit.
Your crank is probably not bent , it takes a big crash or something to bend one. there is an adusjment nut and lock nut to set them back up. could be LH thread on the left hand side
Feb 12, 2011 | Dynacraft Next Turbo Children BMX Bike
I just had my daughters 2002 searing serviced in the area she goes to school. I had new tires and a front end alignment done for a little over 500.00 all done October 6, and now, maybe 1500 miles later...
yes definably should been taken care of before the alignment was done
u can' t get a accurate alignment done with loose parts up front (ball joints get loose before they break)
and under most circumstances ball joints don't totally fail in a 2 month period of time
Now if your daughter drives on a lot of rough roads or hits a lot of pot holes and ball joint was dry (not greased in long time) (alignment shop should at least greased front end parts if possible some factory and cheap aftermarket ball joints are sealed and u cant grease them) There a slight chance ball joint could failed that soon but i highly doubt it
Now should u go back to shop ?? call them and explian to them what happened and see if they will warranty there work if they will more than likely day u brought in your car they where busy and behind and it just got over looked
if they wont warranty there work i would go some where else they did bad job first time and wouldnt want them doing same again
Far as cost goes that a hard one to tell u cause shops labor rates greatly across the country and even from shop to shop in same towns
for cost i would make a couple calls to few shops and get a ball park figure for your area
Dec 27, 2010 | 2002 Chrysler Sebring
Front end
need to see if its upper ball joint or lower ball joint or strut itself use greese
Feb 20, 2010 | 2001 Dodge Stratus
Spin ball. Cursor barely moves on screen.
Have ya tried removing the ball and cleaning the infrared screen under the ball with a cue tip? Also get all the finger grease and gunk out of that area too. You can remove the ball with a pencil or pen, use the dull end of the pen or the eraser end of the pencil, so you don't divot/dent the ball.
Aug 17, 2009 | Logitech Trackman Wheel 904353-0403...
FRONT DRIVER SIDE TIRE, NEEDING SOME GREASE KIND OF NOISE
Yes this is Necessary. But, I would not let it go! If not repaired the Ball joint could come loose at a later time and Leave you Struggling to keep it out of the Ditches. I would replace the Shocks on the Front also. a Very Bad Shock could Cause Loss of Control.
Jan 14, 2009 | 2005 Mazda 6
kawasaki Full Suspension Mountain Bike Men Logo
81 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
