Question about Promaster USB 2.0 Pocket Card Reader for Compact Flash Cards (8843)
Can't use with 4gbyte cards
My Promaster digital compactflash card reader (code 8843) works fine with my 2gbyte cards, but Windows Vista gives the message "Please insert a disk into Removable Disk (F:)" whenever I try to access one of my 4gbyte cards.  Is there a way to update the software of this device to correct this problem??
  • congabongo Apr 10, 2009
    ditto on the problem with 4gb card...
I have the same problem. I emailed Promaster about why a 2 GB could be read by the Model 8843 CF reader, but a 4 GB card could not. This is not exactly a solution, but here is their response:
"It is possible that the card reader you have was manufactured before there were 4 Gigs cards on the market and the controller on the reader is not able to address the extra memory. It is a rarity, but it has happened. That or just an electrical timing issue which is also rare but happens.
As technology changes and expands, we race to catch up, in this case you might just have a card reader that is just too old. We manufactured that particular card reader for a long time and I am positive it went through some enginering changes as the technology changed.
My suggestion is to take it to the original (or closest) dealer with the card reader. If you purchased it within a year I am sure the dealer will swap it out for you, beyond that I cannot say."
Posted on Jun 23, 2009
Printer does not read memory cards or card reader
Here's the list of compatible digital media memory cards:
  • CompactFlash I & II
  • SmartMedia Card
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • Microdrive
  • 4 Built-in Card Readers
  • xD Card
  • Sony Memory Stick Duo (with adapter)
Aug 11, 2011 | Lexmark P315 InkJet Photo Printer
Promaster Digital card reader error
These are very cheap just replace it with one from eBay. They cost less than $5 USD
May 02, 2017 | Promaster USB 2.0 Pocket Card Reader for...
I have a finepix s5500 camera but the softwear is xp and i need a vista version, is it possible.
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Oct 17, 2009 | Fuji Finepix Z20fd Digital Camera
Need to upgrade video card
Good Day Sir, your motherboard is capable to handle windows vista and 7, upgrade it to 4gbyte ram and any high end graphics card with PCIe 16x. good luck. check out this website:
http://es.shoppydoo.com/precio-placa_base-asus_p5gd2_x.html
Oct 01, 2009 | ASUS P5GD2-X (610839128686) Motherboard
Compactflash card writer/reader erasing pictures
I discovered that my particular problem was caused by bent pins in the card reader. I straightened them and re-aligned them and reader is back to normal.
Feb 20, 2009 | Dynex USB 2.0 CompactFlash Card Reader
SanDisk Extreme Firewire Reader not recognized by Vista machine
I opened the reader mechanically by unscrewing the two screws beneath the rubber pad in the bottom. I saw that two pins were pushed out of the connector. By carefully pressing them back in again I found that after closing the unit and carefully inserting a CF card it was working again Yipee!!
Jan 05, 2009 | SanDisk Extreme FireWire 400/800...
Got a card intializing msg!!!
The S7000 has always been known to have some problems with regular CompactFlash cards, with both power drains and limitations reported (the S7000 seems unable to handle CompactFlash cards above 2GB, as it doesn't support FAT32). I imagine it's possible that there are other potential problems associated with this.
It's usually recommended that, instead of using CompactFlash cards, you use either xD-Picture Cards or IBM/Hitachi Microdrives, which are both fully compatible with the S7000.
May 11, 2008 | Fuji FinePix S7000 Digital Camera
Need Driver
Hi, you have unfortunatly met the same fate as a lot of unsuspecting people. VISTA does not support most older plugin devices or earlier version soft ware. It is possible to run an old old program designed for WIN 3.1 but none of the later top line products. It is the same for Hardware. My advice is to locate a set of drivers for your new computer system that work with XP and delete VISTA then install XP. Regards mistyman
Aug 09, 2007 | Canon PowerShot A40 Digital Camera
PDC 1100 camera with Windows NT4/Me/2000.
Windows Me and 2000 - A new camera TWAIN driver (version 4.1e) compatible with Windows Me and 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible. Windows NT4 - No TWAIN driver is available for use with Windows NT4. However, the PDC 1100 accommodates a removable CompactFlash memory card (maximum 128MB) for storing images. When used with a Windows NT4-compatible CompactFlash card reader, images can be dragged and dropped from the camera's memory card to any location on your computer's hard drive.
Sep 21, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Promaster USB 2.0 Pocket Card Reader for Compact Flash Cards (8843) Logo
137 people viewed this question
Top Promaster Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Promaster Camera Expert? Answer questions, earn points and help others
