Question about Hoover F5807 SteamVac Wet/Dry Vacuum
Directions on how to operate the vac from beginning to end
    President:
  • 389 Answers
Hi! Go to www.hoover.com then click on the "Customer Service" tab. In the next window, under "Product & Support Information", click on Product Manuals and Information. In the next window enter your model number and click on Search. You will then be able to download the complete product manual. I hope this helps. I value your feedback so please remember to rate this response. Good luck!
Posted on Feb 21, 2009
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
I have a Bissell power steamer # 1693 and no directions need directions on how to use it
This is Vac's Etc. In Lake Charles.
E-mail Vacs.etc@live.com
Google search
How to use / Instructions for Bissell power steamer # 1693
Hope this helps....
Nov 04, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
UNABLE TO FIT BELT ON MY ULTIMATE UPRIGHT G BAG VACUUM CLEANER.
You need to disengage the carpet head from the vac itself. Do this by lifting the headlight and rotating the thumb lock underneath. Then release the carpet head by turning the square dial below the light. Once you have lifted the head off the vac you will see from the backside of the head there is a belt hook holding the old belt in a twist.
pop the brush cover off at the bottom of the head but note which end of the brush goes right and left. Slide the new GENUINE belt onto the brush roll and inspect the brush for hair and thread caught at the ends.
Reisnatll the bottom plate in reverse order making sure the brush sits level in the housing.There are leveling blocks at each which are color coded.
Once again rotate the square dial on the front of the housing, in both directions if necessary ,You will feel the dial tension as it hooks your new belt inside the housing and twists it into installation position.
Reinstall the head in reverse order onto the vac.
Aug 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
MY EUREKA WORLD VAC ROLLERS ARE NOT SPINNING. THE LIGHT IS ALSO BURNED OUT. IS THERE A CONNECTION BETWEEN THESE TWO EVENTS?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=813214
Generic problem for all Vacuums
Posted by agreene1038 on July 21, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the Eureka brushrolls have a sensor in the brushroll that indicates that the brush is moving and the sensor and the light are linked together – you may have a bad brushroll – to check that you need to remove the brushroll, stand it on end and spin it freely, if it does not spin the bearings could be bad or needs to be replaced with a new brushroll and a new belt. The belt change is every 4 to 6 months for the best cleaning. . If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 | Vacuums
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Directions for use of model#8920 07302C
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=568988
posted by chedgpeth on May 04, 2008
directions for use of model#8920 07302C
Have the same problem? Click HereX
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Clarification Request by ukvacfan, posted on May 04, 2008 Who is the company that makes this model?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. We need to know the Brand name and Model # for the item B4 we can get you directions. I suggest that if for example, it is a Hoover or Eureka then go to the website address of Hoover.com or Eureka.com to find a cust serv phone # and then call them for the owners manual of that particular vacuum. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 04, 2008 | Vacuums
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Hoover F5807 SteamVac Wet/Dry Vacuum Logo
259 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
