Question about Carrier Heating & Cooling
Replace thermostat Purchased a HUD home and some one took the thermostate with them when they left, carrier model 38byc048340, but I'm not sure of the wire color codes the wires i have are listed below. Does carrier have a standard color code for the thermostat? white yellow red brown green orange blue
  • Perry Putnam
    Perry Putnam May 11, 2010
    Do you have a/c and gas heat or do you have a heat pump?
  • 3,361 Answers
Typical color codes in Florida are;
white to W1 for heat
yellow to Y for compressor
red to R-RC-RH for power in
brown to W2 and or emergency /auxillary heat
green to G or Fan
orange to reversing valve(o/b)
blue to common.
You can open the control panel on the unit to verify these colors and components.
Posted on Feb 21, 2009
Where is thermostate on 1998 chevy cav
If u have a 2.2L, I have the same car and just replaced the thermostat and it took 10 times longer to find it than to replace it!!! There is a "Thermostat Housing" on the engine itself, front of motor, left side but IT DOESN'T GO THERE!!! There is a 2-Bold, 2 or 3 hose, bracket out in front, very accessible that it goes in!! I found mine just searching diagrams of chevy cavalier's and found it in a 03'!!! The place it goes comes off of the "Thermostat Housing" and runs right up front of the car, left side!!! Hope this helps some!!!!
Jun 27, 2014 | 1998 Chevrolet Cavalier
I need a booklet for directions on how to operated & set this thermostate, as I just purchased the home.
Since you didn't give the furnance/air conditioning model number or the model number of the thermostat controlling them, it is impossible for us to give you good advice or instructions.
Suggest you obtain the make and model number of your thermostat and either google it for the owner manual or come back on the site with it and we will try to help find the owners manual for you.
Sep 15, 2011 | Heating & Cooling
I REPLACED WATER PUMP, FAN CLUTCH, TOOK OUT THERMOSTAT, REPLACE RADIATOR CAP, TOOK RADIATOR TO GET CLEANED AND STILL OVERHEATS WHATS THE PROBLEM
about the only thing left is that the engine block & head may be blocked, also check that the radiator hoses have not gone soft & flatten, especially the bottom one, because you have done everything else that can be done, at worse it could be a blown head gasket......hope this helps.......cheers.
Sep 01, 2011 | 1983 Oldsmobile Cutlass Supreme
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
Thermostates not work properly,
I had the same problem just read the instructions very careful and you will be able to figure that out. I mine has two settings in the morning and two settings in the afternoon.
Jan 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Think in need to replace the thermostate
locate the thermostat housing.usally located at the other end of the top radiator hose.remove the two or three bolts holding it.if u havent drained sum fluid it will leakwhen u remove.have new gasket and thermostat handy pull old out an replace. thats it.When replaceing bolts DON'T over tighten its easy to crack thermostat houseing.replace the colant u lost make sure no leaks. parts are cheaps!!!should be pretty easy.
Aug 09, 2009 | 1991 Ford Explorer
Carrier Thermostat Model TSTATCCPB501 ER code
I gave up and called a local HVAC business. This thermostat is discontinued and a new one will be purchased and installed.
Dec 15, 2008 | Carrier BCA101R Air Conditioner
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
192 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
