Question about Pioneer VSX-D458 Receiver
I need the codes for the remote control
I am looking for a manual were i can the codes for the remote controle to programe my Tv and the DVD on ità
pleasec ontact me if anyone ca help
thx
5.1 dolby ----- vsx-dv458
control----------cu-vsx126
rajiabirached@hotmail.com
5 Suggested Answers
  • 4 Answers
SOURCE: universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Posted on Jun 12, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Posted on Nov 08, 2008
  • 10 Answers
SOURCE: How do I set up a bluray player with my Pioneer
idk
Posted on Apr 06, 2010
Im looking for codes for a sylvania tv
The codes to try for Sylvania TVs are 0054 0030 0171.
The manual and codes are available from the One For All support site: http://www.oneforall-na.com/remote.php?type=URC%203021 . The link for codes is at the bottom right of the page.
However, most remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, then you may need to get a newer remote.
I hope this helps.
Feb 25, 2011 | One For All URC-3021 Remote Control
How do I program ESPN game changer remote control
I have the instruction book. What devices are you looking to proggram - type and brand??
Nov 21, 2010 | Televison & Video
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
Can't get my Phillips universal remote to program my tv controls on my sv2000 t.v/dvd combo.
If you already tried the tv codes for your make of tv, the manufacturer suggests using the dvd codes for your same tv make sometimes they use the dvd codes to activate or control the tv on some of those tv/dvd combos. If all this fails you can always use the code search procedure described in your remote's manual, but you need to be patient because this procedure will scan thru all the programmed codes(vcr,dvd,sat,cabl etc.) one at the time.
Jan 16, 2010 | Philips Universal PH301S Remote Control
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
I need the remote control code for this unit to program into my TV remote
The Code you are looking for is 422. It is hard to find since it is listed only under DVD players and not combo players.
May 31, 2009 | Samsung DVD-V9800 DVD Player/VCR
Jumbo remote control wont program
if u still have the manual to it---- look at the top right corner of page 11.. there are separate codes for for emerson tv's listed as---
TV VCR/DVD
036 041
39 027
155 002
198 008
231 u could try these---
good luck.
Feb 13, 2009 | GE RM24912 Universal Remote Control
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
Open Questions:
Pioneer VSX-D458 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
