Question about Northstar Generator 20 Hp, 13,000 Watt, Gasoline
I have a North Star Model 5500 belt driven generator. I am using
A 1987 Chevy S10 engine to power this generator. While I was getting the combination to work together I revved the engine fairly high and must have overrevved the generator. There was no load on the generator at this time. Now I cannot get the generator to produce any electricity. This is a new unit and it did produce electricity prior to my overrevving it. Is it possible that I damaged one of the diodes or the capacitor while overrevving the unit even though there was no load on it at the time? Thank you for any advice that you may be able to give me about this situation. Langley McKinney
  • langley_mcki Feb 22, 2009
    Thank you very much Carl. I greatly appreciate your response.
    Langley
  • 169 Answers
Yes it is very possible that you blew 1 or more diodes in the rotor when you overrevved the generator. You also likely shorted the MOV devices that go across the diodes as well. What happened is that the over speed of the rotor caused it to make a much higher voltage than it was designed for and something had to give. I'd suggest that you also look at the capacitor that connects to the stator windings (it's a little like a voltage regulator), you've probably exceeded its voltage rating.
This is pretty much why there are governor mechanisms on generators, much more than 20% or so overspeed makes nasty things happen.
Carl
Posted on Feb 22, 2009
North star 5500 generator works fine but on voltage output
It's very common for the connectors between the alternator and power outlets to come loose on these. Give them a check and tighten as necessary.
Oct 13, 2014 | Northstar Generator 9 Hp, 5500 Watt,...
My north star 5500 generator starts but does not put out any electricity through the plugs
Check the connections between the alternator (generator) and the regulator/output connectors.
North Star Generator Parts
Hi, you can find them on amazon. Take a look here: Portable Generators from Briggs Stratton. I hope this was helpful. Cheers
Oct 08, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
Where is the power steering pump on a 1987 lincoln town car, and how do i replace it?
Pretty much all power steering pumps are on the front
of the engine & belt driven
You have to loosen the drive belt & just unbolt it
Easy to say, not so easy to get to
May 30, 2011 | 1987 Lincoln Town Car
I need a picture/or diagram of the serpentine belt routing on a 1998 Cadillac 4.6l north star engine. Car is a De ville
I need a diagram of how to replace a serpentine belt on a 1998 Calilic 4.61 north star engine
Dec 22, 2009 | 1998 Cadillac DeVille
How to flash field north star 5500 generator
wire a 120v 15a to 9vdc or 12vdc battery make sure you have no voltage out of the 240 side. with the unit running plug into the 120v receptacl QUICKLY pull out. check power out put. if it did'nt work check your battery, than do it again twice as long. you must check all component before doing this to make sure you don't have any other fail-er. this is danger-us be careful. good luck
Oct 08, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
1987 chevy S10 engine idle problem
relace the throtle air idle valve.The temp switch will allso cause this problem.
Jul 19, 2009 | 1987 Chevrolet S-10 Pickup
My NorthStar 5500 generator head no longer produces any electrici
Specs do not mention a maximum safe rpm but the recommended shaft speed is 3600rpm. Even though it isn't a premium product I can't imagine the manufacturer would be so foolish as to design it so it breaks if that speed is exceeded by a reasonable amount for a short amount of time. The big question is what is a reasonable amount - I reckon a safety margin of 25% would be reasonable for a budget priced product and up to 40% for a premium product.
Over-revving is unlikely to do very much damage to the stator but the armature is at risk of damage and being brushless or self-energising, unless there is visible damage it is a difficult item to test without dedicated equipment.
I suggest you recheck all plugs, connections and cables and if no faults are found contact the manufacturer or dealer for advice, costs, etc...
May 08, 2017 | Northstar Belt Driven Generator Head 5500...
North Star 5500/ lost one leg of the 220v
Small generators like this almost always have 2 stator windings 180 degrees out pf phase, that's how it makes the 220.
At the back (maybe side) of the outlet box should be a molex type plug that has the wires from the stator, get an ohm meter and measure them (with the generator shut off of course). You should find that you've got 4 wires in the plug, 1 wire for each end of 2 coils. From one end to the other of each coil you should measure less than an ohm, between the coils there is usually no connection, but some models have the neutral ends of each coil connected together inside the generator housing.
It sounds to me like you've got one of the power windings open...
Carl
Oct 13, 2008 | Northstar Generator 9 Hp, 5500 Watt,...
Engine replacement
The best publication out is printed especially for this its the HOLLANDERS INTERCHANGE BOOK this is the bood and program wrecking yards use to know which parts fit which cars and for how many years.
Sep 14, 2008 | 1987 Chevrolet S-10 Pickup
Northstar Generator 20 Hp, 13,000 Watt, Gasoline Logo
289 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
