Question about Kenmore 15944 Top Load Washer
I changed the coupling and now there is a burning smell? Please help.
  • Anonymous Apr 01, 2009
    yes, i replaced my coupling and have the burning smell as well. I hope it goes away and soon!
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
I can smell burning oil smell inside my car sometimes when i turn the heat on.and the engine light also came on couple of days after. i jus changed the oil and filters 3 weeks ago. can someone please
depending on the type of car, you might have oil leaking directly onto the exhaust system, which is dangerous as it could possibly ignite. I would take it back to the oil change place and have them double check the oil filter to make sure the seal isn't leaking. AutoZone or Advance Auto can hook a mini scan tool to the car and tell you why the light is on.
Dec 04, 2012 | Cars & Trucks
Rubbery smell, sparks from inside back panel
Any luck with your problem from 2012? We have the same issue.
Sep 11, 2012 | Maytag MERH752CA (Electric) Kitchen Range
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
I have a Kenmore series 90 washing machine, Model 110.26902691. I changed the motor coupling last week and after being proud of my work, I was able to complete one cycle before I started to smell a burning...
Considering the info you`ve provided, specific to the history of replacing the drive coupling. You stated that right after replacing the coupling it started to smoke or as you said "I started to smell a burning smell". Can you identify if it was electrical, or was it rubber/plastic ?
I`ve seen these coupling`s when not put on correctly start to rub against the motor or the transmission, you might want to double check your work with installing the coupling.
Aside from that it could possibly be the motor, but if it agitates and manages to advance through the wash & rinse cycle up to the spin, I`d be skeptical of a motor problem. You should check to make sure the lid switch is being fully closed, in the event it isn`t closed properly the unit will do everything except spin.
Hope that help`s. Good luck.
macmarkus :)
Dec 08, 2009 | Kenmore 24902 Top Load Washer
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15944 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
