Question about Emerson Smartset Clock Radio
Radio/tuner reception I just bought the ic200 and found the reception for both am and fm to be very weak.  Does anyone know how I could boost the reception?  I know the antenna is in the AC cord.  Is there anything that I could plug the AC cord into to boost the signals?
    President:
  • 814 Answers
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the Clock/Radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Posted on Jun 12, 2009
    Scholar:
  • 66 Answers
The wire that attaches to the line cord... remove it. now find the ground in the radio. attach a second wire to the ground. attach the ground wire to the ground screw on your power outlet from you wall or ground rod in the ground. next attach a longer wire to the other wire.
another choice would be to attach the ground wire to a coax cable at the shield and the other wire at the center of the coax. run the coax cable to a higher location, then from the shield at the other end connect a piece of wire (234/frequency in MHz) answer in feet, this is the length you need. now attach another wire from the center going the opposite direction using the same length of wire as the one you just hooked up. orient the wires so they are horizontal and 180 degrees apart. A good stick or something straight to hold the wires and tape them on. Any size wire will work. now you have just made a directional antenna. Rotate it until the signal is better. If it is but still needs help then add the amplifier. add it inbetween the antenna you just made and the radio. The antenna will hook to the input of the amplifier and the output of the amplifer will go to the two wires on the radio. ground to the ground and output to the wire that originally was connected to the line cord. Phew!
Posted on Aug 26, 2012
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
I am listening to the radio part and it keeps switching from mono to stereo what do I do to fix that problem
Back in the day this happened when the signal for FM bets weak. It is worse during day light hours. I don't know if you can boost reception with this.
Oct 21, 2014 | Legacy LDSN7 Touch-screen 7" Motorized LCD...
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    Dec 29, 2009 | RCA RP5430 Clock Radio
    How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
    I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
    Aug 16, 2009 | Bose Wave Radio
    I get FM reception but no AM on my '05 Jetta factory radio..help?
    it might be that your gadget posses a wrong panel written AM when there is no am tuner. If you can check inside it whether it has a choke wound with copper wire for AM reception. If its missing, its aint gonna have any reception
    Sep 20, 2017 | 2005 Volkswagen Jetta
    No AM radio, very weak FM radio reception
    i would pull set out and have a look at the printed circuit from the aeriel to where ever it goes to in the circuit board ,if i couldnt repair it ,then i would have a nice drive to carrefour(hypermarket) and buy myself a belson which has usb/sd card/cd and they do one with blue tooth all for about 100€ and fit that .who needs a cd changer when you can put a 2 gb sd card in that can hold 40 +cds or plug your i pod in
    Feb 16, 2009 | 2000 Honda Odyssey
    Emerson Smartset Clock Radio Logo
    651 people viewed this question
    Top Emerson Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
