Question about Espresso RMI La Cimbali Espresso Machine
Need parts for cimbali m2 press drive screw and follower and grinder assy
  • 137 Answers
Try at ;
if you cant find ill contact personaly at oemmeci and request the information.
Posted on Mar 26, 2009
How do I set the coffee dose?
Too detailed for direct answer. Get operator's manual for dose instructions. Some machines may require programing key (service tech only)
Sorry for this answer as the dosing control is in-bedded with all dosing variances which is considerable. Though with practice it's possible to set it. Have you service tech walk you though the 'operator' or 'customer' programing steps.
Dec 30, 2013 | Espresso RMI La Cimbali Espresso Machine
I need to see a wiring diagram for a la cimbali espresso machine m2
These super automatics really require a service tech. Please contact your vendor or for current contacts
Nov 17, 2012 | Espresso RMI La Cimbali Espresso Machine
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
I am repairing a LaCimbali M2 BarSystem that has a broken gear (Nylon) that transfers Torque from the Motor to the drive shaft on the grinder. Can this gear be purchased separately?
Sorry no, the gear drive assembly comes complete with the motor drive. Broken gear is usually caused by something getting into the dose chamber. I've found may an object stuck in the chamber, Don't leave stuff on top of the machine. Don't use hard cleaning pills (check old coffee 'pucks' for unmelted pills) Gross overfilling of coffee will also break gear. Check for oversized coffee pucks (double dosed?)
Oct 11, 2010 | Espresso RMI La Cimbali Espresso Machine
What does error66 mean on an m2 and what are tge possible solutions?
No 066 mean Failure to read impulses by volumetric flow meter of turbine during coffee dispensing.
The Possible causes are.
1. No Water - check water mains.
2. Broken water pump- Check water pump if it stuck or completely damage replace.
3. The coffee dose is too much- reduce the coffee dose.
4. Coffee ground is too fine- Adjust grinder to more gross coffee.
5. Clogged filters -Replace filters.
6. Coffee solenoid valve clogged or defective -Clean it o replace it.
7. Broken flow meter- Clean from scale deposits or replace.
Sep 29, 2010 | Espresso RMI La Cimbali Espresso Machine
Need parts for the lisle 91000 grinder
I need the drill bit holding assy. And a dressing tool assy.
Sep 15, 2010 | Lisle 91000 LISLE DRILL GRINDER U.S.A
The grinds are too course on my La Cimbali M2 Barsystem. Where is the lever, and how do you move the lever in order to make the espresso grinds finer?
The ginder udjustment for M2 is behind the coffee bean hopper. It is a small level hundle. You have to pull it up and rotate it step by step clockwise for more fine.
May 08, 2010 | Espresso RMI La Cimbali Espresso Machine
My barsystem m2 machine shows that it needs to be serviced.
Check out this site it will give you a list of all the dealers.
Apr 22, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
308 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
