Question about Mitsubishi Raider 2006-2007 Car Radio Wiring Harness
I would like some help finding the wiring diagram to a Kenwood DPX710MD car audio CD and Tuner please. My son has recently purchased this unit second hand, and I want to help him install it, but there is no information on the unit showing the harness wiring for it. Can anyone help plase? Many Thanks
  • james kappers
    james kappers May 11, 2010
    what type of vehicle is it going into.
  • 95 Answers
If you send me your email address i can email you a copy of the manual.
Posted on Feb 21, 2009
Need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Nov 16, 2009 | Kenwood KDC-W3534A CD Player
Wiring from a kenwood kdc mp332 to a clarion rdb245d
and the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
orange/white illumination
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 21, 2008 | Clarion DB245 CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
KVT 617 CD/DVD "reads" but only audio from tuner
Ok, so I called Crutchfield, where I had purchased the unit, and the guy there said this is a common thing. Believe it or not, it IS the wiring. The guy said the blue wire on the harness needs to be connected to the blue/white wire on the Kenwood unit. Which is weird, since it's usually color-coded. He said the blue wire is a 12-volt amp wire, which works with the tuner, but when you take it off tuner, it kills the 12 volts and so you get no sound.
I haven't fixed it yet to be sure it works, but I thought I'd post this anyway, in case someone else is waiting on this. I'll post again if it doesn't work. :0)
Jan 29, 2008 | Kenwood KVT-617DVD Car DVD Player
Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
May 30, 2007 | Kenwood KDC-MP828 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Help!!
if you have a amplifier to it you might want to check your remote wire there is two of them they are blue check and see if its connected to the one that says amp not antena remote.i think that that is you problem
Nov 22, 2006 | Kenwood KDC-MP628 CD Player
Mitsubishi Raider 2006-2007 Car Radio Wiring Harness Logo
244 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
