Question about Acer Aspire 7720-6569 Notebook
Aspire 7720-6569 laptop automatically shutoff and won't turn on.
I was on my laptop and it automatically shut off. It will not turn on. It was on the charger. What can be wrong and how can i fix it?
  • 479 Answers
Please try following DIY
1.Please remove the battery and then press the power button for a minute without connecting the adaptor then refix the battery and check whether it is working.
2.Check after removing the battery with adaptor only.
3.If then also it is not working check whether the num lock is responding if yes then this is a RAM refixing or changing issue otherwise a motherboard issue if the adaptor is working fine.
Posted on Feb 21, 2009
How do I set coffee maker to shut off in 2 hrs and how to use clean cycle
Not knowing which model you have, here are the instructions for my model. Perhaps yours is the same.
"The Automatic Shutoff
Time can be programmed anywhere from immediate shutoff after completion of the brew cycle up to four hours. When the coffeemaker shuts itself off, two tones will sound. Two hours is the default time. The 0:00 setting shuts the unit off immediately after brewing is complete.
To check the current setting, press and hold the On/Off button and the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the On/Off button until the red power light and LCD display begin to flash. This signals that you have entered the Set Automatic Shutoff mode.
Press the Hours and Min buttons to scroll forward through the digits until desired time appears. The first setting which appears is preset at 2:00. When it's at 4:00, the next press key of Hour will roll back to 0:00, since four hours is the maximum Automatic Shutoff setting. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The Automatic Shutoff Time (ASO) may be 8 9 programmed either before or during coffee brewing. You may also re-program the ASO time when brewing has been completed. If you do so, the Grind & Brew™ will automatically account for any time that has already elapsed after brewing. For example, if you set the ASO for 40 minutes and 25 minutes have already elapsed, the Grind & Brew™ will shut off automatically after 15 minutes (40 minutes minus the 25 elapsed equals 15 minutes)."
Mine doesn't have a specific clean cycle, but to decalcify the unit, add 1/2 vinegar to 2/3 water in a full cafree and run it through. If it's really calcified, turn off about 1/2 way through and let it set for an hour. Then turn it on and finish, Remember to run a pot of clean water through the wash out the vinegar taste.
Jun 24, 2016 | Cuisinart Coffee Makers & Espresso...
Acer Aspire 5733 Series won't start
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/intocircuit-acer-aspire-5733-ac-adapter-65w-19v.html
Nov 29, 2012 | Computers & Internet
It shut down automatically and won't turn on after that.
The computer/laptop is heated up too much on the same place. You have to wait about 5-10 minutes if it automatically closes, so it it gets cold.
Dec 29, 2011 | Sony VAIO Y Series Notebook VPCY118GXBI
My acer aspire one d255 won't shutdown. What should I do in order to shut it udown.Thank yo
keep the power button pressed for some time it would automatically shut down
Aug 17, 2011 | Acer Aspire One Netbook
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
My acer aspire 6920g will shut down automaticly when i want to log in to my system, after the boot menu the cooler is turning off for 1 second.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Apr 26, 2011 | Acer Aspire 6920 Notebook PC
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
tones will sound.
NOTE: Automatic shutoff may be
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
elapsed, the unit will shut off automatically
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Acer 5002 laptop shutoff randomly
Have your DVD Rom checked..I had a similar problem XP not loadin... It was because of compatibility of the rom... like wise it could be a mother board problem..
have it checked up by an acer service person
Oct 16, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 7720-6569 Notebook Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
