Question about Asko T711 Electric Dryer
Wrinkly clothes A few months ago purchases an ASKO dryer and it seems no matter how small my load is, everything comes out wrinkly. Any suggestions?
  • albert getty
    albert getty May 11, 2010
    even on perm press?
  • 6,784 Answers
Here are a few tips to combat this issue.
•Select a shorter drying time.
•Remove items while they still hold a slight amount of
moisture.
Remove items when cycle ends and fold or hang
immediately.
This will prevent wrinkles.
Posted on Feb 21, 2009
  • Michael Masters
    Michael Masters Feb 21, 2009
    Decreasing the load size will help prevent this issue as well.
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
ASKO washer WL6511XXLPP
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Mar 22, 2009 | Asko WL6511W Front Load Washer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Aslo T700 Dryer Heats but won't dry.
TRY DISCONNECTING THE EXHAUST FROM THE BACK OF THE DRYER AND RUN ONE LOAD THROUGH IT. IF IT DRIES O.K., THEN YOU HAVE A RESTRICTION IN THE DUCT WORK.
Apr 07, 2008 | Asko T700 Electric Commercial Dryer
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Asko T711 Electric Dryer Logo
143 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
