Question about Gigabyte Computers & Internet
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
I am trying to connect a Minidisc Deck (MDS-PC2) to my PC. I have an optical cable running from the optical output of the deck to my PC spdif input. I have another optical cable running from the deck optical input 1 to a separate SPDIF add-on bracket that is connected to the motherboard via its SPDIF header internally.
My sound works fine otherwise, and the deck outputs sound via the headphone jack, so both machines are working correctly. The deck is set to accept the optical 1 input, which the motherboard is connected to. I get no sound, in Audacity or Windows Sound Recorder, from the deck. I have set eh Realtek Audio Manager settings, in the Digital In/OUT settings to:
Ouptut Sampling Rate - 44.1 Khz (the Minidisc ATRAC rate, I believe)
Output Source - Output Digital Audio Source
and the status says:
Lock
PCM 44.1Khz
Valid
No Copy
Can anybody help, I need to get this working so I can record Minidisc audio from the deck to WAV files on my PC for film editing.
Thanks in advance, David
  • 77 Answers
Hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Posted on Feb 25, 2009
What does d-in lock mean
http://www.minidisc.org/manuals/sony/sony_mdsje470+770_manual.pdf
Here is a link to the manual for this deck check it out....
I think this means either the digital cable is not connected properly or possibly you are running into a copy guard problem. If you try to connect and record from some digital sources the source or the disc (if already a digital copy) has a tone inserted so you cannot make a copy of a copy. I also found if you digitally try to record from some TVs or other digital output sources this signal is added to prevent this. The work around copy guard is to make an alalog copy using rca cables.
Apr 06, 2014 | Sony MDS-JE470 Mini Disc Player
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
When i press the record button , i get Dinunlock c71
The source you are recording from cannot be read from; you slected a source without a connection, you have a digital source which has copy guard to prevent recording from it...
Check your input selector setting and your cables and the cables on the component you are trying to record from.
If optical in rare instances you are trying to record 5.1 or 7.1 encoded sound to older stereo on the deck - you can do this with an optical decoder box available on ebay without it all is connected correctly but it won't work.
Nov 07, 2013 | Sony MDS-JE480 Mini Disc Player
Sony MDS-JE520 Mini Disc Machine no operation, standby led is illuminated, but pressing on/off button it does not respond
This is from my own experiance. I inadvertedly bent the cover of my deck and had the same error.
The minidisc is blocked in the loading mechanism. Too much weight on top of the deck can bend the cover and the metal support which is above the loading sledge. The slider is then blocked. When you connect the power you can hear a motor trying to move for as short instant.
Disconnect the deck from the power supply.
Take of the cover and check if the support is bent. carefully bend it upwards, if so. Reconnect power and check if the deck powers up..
That's my solution which worked for me.
BTW I second Obertellis advice to find a MDS-JE780 (or MDS-JB980) they are the most complete decks ever made by Sony
Jul 25, 2010 | Sony MDS-JE520 Mini Disc Player
I have a problem, minidisc deck mds je 480
HELLO
C13 is what is called a "Protection Error". This normally happens because the if you look on the bottom edge of the minidisc itself you will see what looks like a plastic strip or tab at the bottom left.
Pull it to the left for it show fully and this will enable you to record onto the disc. Move it right, and this will PREVENT recording from taking place.
If you have the unit connected up by the optical lead and you're trying to record the audio from a DVD unit, the MD deck is probably telling you what you are trying to record is copy protected. I never use the optical lead, just hook it up by good quality interconnects and the recording you get is superb. Both DVD & CD audio!
All The Best! :-)
Jul 23, 2009 | Sony Audio Players & Recorders
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
Can i transfer music from MP3 player to minidisc?????
USing the sonicstage software you should ba able to do it. If you can get the software working
Feb 24, 2009 | Sony MDS-JE480 Mini Disc Player
Din Unlock C71
your deck is expecting a digital signal provided by optical cable.
Hence the error message you see. If you want to record using RCA cables, you will have to set your MD recoder so to use analog input.
Press the INPUT key repeatedly to select the Analog input, then connect your RCA cable to the Analog input and start recording.
You may have to adjust the recoding level (or volume if you will).
OR you get an optical cable and then use the Digital Input 1 or 2.
See page 11 of your user manual for detailed instructions.
Cheers
Feb 21, 2009 | Sony MDS-JE470 Mini Disc Player
Computers & Internet Logo
506 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
