I cannot get my printer to print addresses on 6' x 6' envelopes
I lost my cannon BJC-1000SP installer, can u install this?
Posted on Feb 23, 2009
How to print envelopes
1.Buy envelopes at any office supply store. They come in all shapes, sizes, textures and colors, so choose ones that go with the type of invitation you are sending out.
2.Open Microsoft Word 2007 and click on the Mailings tab.
3.Click on Envelopes in the Create section.
4.Click on the Envelopes tab when the Envelopes and Labels box comes up. The box will probably come up with the Envelopes tab open, so you may not need to do this.
5.Enter the recipient's address in the Delivery Address box. Invitation envelopes should include the names of everyone invited--for example: Mr. and Mrs. Smith, Mrs. Smith and family. Don't worry about the font at this point--you can change it later.
6.Enter your return address in the Return Address box. As with the Delivery Address, you can change the font later.
7.Click on Options. Use the drop-down menu in the Envelope Options tab to change the size of the envelope if needed. The packaging of the envelopes that you purchased will have information about the size of the envelopes. It is very important that you choose the correct size so that the envelopes print correctly.
8.Adjust the font of the delivery and return addresses. Click on Font in each section and change the font style or size. You can also bold, italicize or choose other options regarding the font.
9.Adjust the placement of the delivery and return addresses on the envelopes. In each section, click the arrows in the "From left" or "From top" boxes. In the preview section below, you can see the movement of the addresses as you adjust the placement. Line up everything so that it looks good to you.
10.Click on the Printing Options tab. This is important because you must select how you feed the envelopes into your printer. Choose the correct way that they are fed, whether they are fed into the printer face up or face down, and if they should be fed in manually. This will all depend on your specific printer. Consult your owner's manual for this information if you are unsure. Click OK and you will return to the Envelopes and Labels box.
11.Insert the envelopes into your printer. Click Print once you have everything formatted and arranged how you want. You should print one envelope first to make sure the layout is correct. Once you've confirmed it printed correctly, print all your envelopes.
Sep 21, 2011 | Canon imageRUNNER 1023 Black and White...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Envelopes won't print
where do i insert envelope to print address?
Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Addressing envelopes
Go to printer folder and Cancel all pending jobs
Turn it off the printer and restart your computer.
Turn it on your printer and
Start over again
Use some program to print the envelope (like MS Word)
Oct 04, 2008 | HP LaserJet P2015dn Printer
Printing envelopes
You have to either use the MP Feeder or an Envelope Feeder. When you send the job to the "Manual Envelope" option, it will beep and prompt before each envelope is printed. Same will happen when you use the "Manual Paper" option.
You will have a hard time printing 1000 envelopes. The printer will print a rated engine speeed for the first 6-10...After that, the narrow media sensor will force the printer to slow down and you will proabably get 5-6 envelopes printed per minute.
Sep 18, 2008 | Lexmark T644 Laser Printer
Envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER IF YOUR DARING.)
Jan 29, 2008 | Brother HL-2040 Laser Printer
82 people viewed this question
jasbo
jasbo
