Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The garage door will not open past 12" and one of the photo sensers is constantly yellow it will not adjust
  • 504 Answers
THE YELLOW SENSOR IS OK
YOU PROBABLY HAVE A BROKEN SPRING ON YOUR DOOR.LOOK FOR A GAP IN THE SPRING.
I DON'T RECOMEND DOING YOUR OWN SPRING.(YOU NEED ALL YOUR FINGERS)
IF IT IS BROKEN CALL IN A PRO.
Posted on May 27, 2010
My garage door opener is a 3/4 craftsman and one light is yellow and the other is green. I put my hand in front of the green light and the green light went off. the other side is a yellow light and it
Hi Vickie,
The safety beam portion of the garage door opener is set up to stop the door from closing if something (car, person, etc,.) is in the doorway.
When the door is open - if you press the hard wired push button (not the wireless remote) the door will either close until shut completely, or begin to close and reverse direction as soon as you let go of the button. When this happens, it *usually* means that a sensor is blocked - and reversing the door motor. If you try yhtis with the remote the door may not move at all or just bump down and stop.
You should re-align the sensors as described in the link below. Good luck!
How to Replace the Safety Sensor for Garage Door Opener Repair Guide Help...
How to Adjust Photo Eye on Garage Door
Nov 03, 2014 | Craftsman Professional 3/4 hp Hydro-Glass...
Garage door senser not working
What doesn't the sensor do with an obstacle?
Feb 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage doesn't come down
The color of your door sensors is normal. Make sure they are pointed at one another and that one of the lights isn't flickering. If the main light is not flashing when the door starts to come down you may need to increase the down force just a tad. It is an adjustment on the rear of the motor unit.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster formula one has one sensor light green and the other yellow. no amount of realignment helps this. the garage door will bounce back up when it hits the bottom and won't stay shut. have tried...
One photo eye should be yellow and the other one green. The problem seems to be your down limit to be set too far. When you stand facing the door behind the operator the limit adjustments should be on the left hand side under the light cover. The down limit is the one closest to the door.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Feb 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage Door Opener Lights
Some craftman operator don't have that feature. Are both photo eye lights green? Feature not available. If the photo eyes are yellow and green feature should be avilable. The operator needs to have a three button wall station. With the light on the operator off press and hold the "light" button for about a minute until the light flashes.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door sensors out of alignment
The lights are suppost to be yellow (power to photo eyes) and green (lined up).
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
