Question about Kenmore Elite 45986 Front Load Washer
How do I get it off control lock?
Even turning power off doen't change
  • chrisgibson Feb 22, 2009
    I have the same problem. We've left it unplugged all weekend and it still is not working.
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
I have a 10 yr. old Baby Lock Esante that when trying to fill a bobbin, I get this error message: Safety device has operated. Check if thread is tangled or if needle is bent, then the machine stops. Does...
I would suggest rethreading the machine to make sure the thread is not caught somewhere, & even change the needle or check to make sure the needle is in correctly & pushed all the way up in the needle holder
& if that doens't help then take it back to the repair shop & tell them about the problem
Feb 09, 2012 | Baby Lock Esante
My horn doesn't chirp when I lock the doors.
My chevy doesn't chirp on the first press of the lock button, it just locks. If you press it again, then it chirps. To be honest, I like the fact that it doesn't chirp first - that just draws attention to the fact that you left your vehicle.
Nov 30, 2011 | 2004 GMC Envoy
I have a 2000 Dodge stratus that won't change
Do the old additive method before you give up....................add one and a half cans of `Sea Foam TRANSMISSION TREATMENT' to it and follow directions. Sometimes that can of stuff is AMAZING! don-ohio
Sep 14, 2011 | 2000 Dodge Stratus
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Headlights wont turn on
sounds like a direct short either in the switch unit or relay also could be anywhere along wire line the best way to fix this is take it to electromechanic shop or buy a repair manual ex:haynes or chiltons and have at it with multitester, light tester and alot of patience and determination, even for techs these things take time and patience, I do not recoomend this for average do it your selfer! but as I am tech and have doen this many times it can be doen by following troubleshooting section in manual.
Jan 14, 2009 | 1994 Honda Accord
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
81 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
