Question about Samsung SyncMaster 731B 17" LCD Monitor
I am trying to connect my samsung computer moniter up to my dvr survalance system. It came with a vga converter. On the DVR it has a BNC connection and the back of my computer has a DVI-D connection and a RGB inport. My first question is do I need the converter since the survalance system is Digital and I have a DVI-D port?
  • 479 Answers
Sure u will be needing a converter .
Posted on Feb 21, 2009
I purchased a system from Lorex model # LHV08C02
Lorex used standard BNC and provides Siamese cables for all their DVR systems; like this one.. If you want to use your own, use 75 Ohm RG-59 or RG-58 with compatible connectors. If using premade cables, use BNC female to female. Power is separate and is provided by the 'wall wart' style power adapter.
Sep 29, 2014 | Home Security
Tip
Tips to transfer DVR (Digital Video Recorder) recordings to your Computer
<p><span>A DVR stores video digitally on an internal memory source. You can move your videos to the main memory system from the DVR.</span><br /> <p><span><span> </span></span><br /> <p><span>1. First insert the software installation disc into your disk drive. Choose an installation destination for the software when you are wants to and accept the terms and conditions. And wait for the installation to complete.</span><br /> <p><span> </span><br /> <p><span>2. Now connect one end of the USB cable to the back of the converter and connect computer on other end.</span><br /> <p><span> </span><br /> <p><span>3. Then plug the second cable which came with the converter into the video output port on your DVR and to the other jack on the converter. This cable is the analog cable and is able to carry video out of the DVR while keeping the image and sound.</span><br /> <p><span> </span><br /> <p><span>4. Now open the converter software that you installed and leave it open while you set up the transfer.</span><br /> <p><span> </span><br /> <p><span>5. Then choose the DVR recording which you want to transfer and start playing it from the DVR controls.</span><br /> <p><span> </span><br /> <p><span>6. Finally select the "record" button on the open software on your computer. Let the recording run through and it will record as it plays.</span><br />
on Dec 24, 2010 | Computers & Internet
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
No osd menu on samsung sde-4001n dvr
yea no osd menu, it was the same for me, but after a couple test, i found thats because it does not detect de vga cord correctly, duno why only with this model, if you use kvm or a dvi to vga cord, happens , i connected a old vga lcd screen and wala! , maybe after a firmaware update may fix the problem :)
Apr 22, 2012 | Samsung Sde4002 8 Channel Dvr Security...
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
Hi, i own a bosch eazeo observation system however i do not have a dvr for the system. will the bosch dvra1081 dvr work with my observation system?
Hi, most certainly it will.
There should be a VCR DIN attachment at the back, and monitors hould have been installed or delivered with a cable for this din connection to get several video in and out to BNC bajonet, and audio out for plugging to the bosch recorder.
I have several used or new of this dvr´s or cable´s if youre interrested.
Dec 06, 2010 | Bosch DVR1A1081 Video Recorder
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
I bought a CCTV system for a school but I have some electric problem that the image looks like it's flashing? what is the problem since Iam new to this. IT's like it has brightness
Line loss from the camera to the DVR or monitor and ground loops are the most common problems. If you only see black and white from a color camera, it typically means the cable from the camera to the DVR is too long and/or has high loss caused by a poor BNC connector.
Excessive brightness can mean the video signal from the camera is too strong. This can be caused by an impedance mismatch from using the wrong type of video coax (cabling).
Additionally, a camera power supply plugged into a different electrical circuit (not the same outlet as the DVR or montior) can cause ground loop problems that can affect the video quality.
Dec 14, 2008 | Samsung Color Fixed Security Camera...
Samsung SyncMaster 731B 17" LCD Monitor Logo
365 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
