Question about Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
  • 3 Answers
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Posted on Feb 23, 2009
Linked r300 to pc running windows7.can print photos but not cd's.
Download and install the latest print cd software from here.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R300/Drivers-Support?target=driver&languageId=1&driverId=324514&defaultOSId=3&DRV_CATEGORY_CODE=CREATIVITYSOFT
Dec 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Close the cd/dvd guide
Is there a button for to close the CD/DVD guide? Your Printer stays on CD/DVD printing mode, that's why
Use it. IF NOT Reset the all settings, Check for your userguide Troubleshooting.
Check epson support page for helfull links.
Aug 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson 300
It sounds that there is a possible hardware failure concerning CD/DVD guide cover. We can try this to resolved that issue:
1. Turn off the printer.
2. Close & open the CD/DVD guide cover for three times and make sure that the CD/DVD tray is not inserted.
3. Close CD/DVD guide, Turn the printer on. If printer is ready, press the maintenance button.
4. Try printing again.
If the above step wont resolved that issue your printer may need to send to a nearest Epson Authorized Service Center.
--->>> Tirzo
Jun 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Dec 30, 2007 | Epson Stylus Photo R300 InkJet Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
