Question about Whirlpool LGR3624JQ Gas Dryer
No heat after a minute of drying
I HAVE A LGR8648LWO WHIRLPOOL DRYER ITS HEATS UP FOR MINUTE AND STILLS SPINS BUT NO HEAT CAN YOU HELP?
  • albert getty
    albert getty May 11, 2010
    there might be a crack in element when it heats up it comes apart then when it cools it reconnects
  • Whirlpool Master
  • 3,361 Answers
Your GAS dryer has no element.
You should remove the vent from the rear of the dryer.
Run on hi heat with no laundry.
Your exhaust temperature should be from 130 to 165 degrees.
If not you have a thermostat problem or a ignitor/gas valve problem.
Posted on Feb 21, 2009
Dryer shuts after one minute
If it heats then you're getting 240 to the dryer. Take off the vent hose and look for a lint build up in the hose and where it connects to the house. Restriction will cause the dryer to shut off the heat to avoid a fire.
Oct 20, 2014 | Whirlpool Dryers
Dryer heats then stops heat
-Thermo is bad. Check and replace it.
Att! Always disconnect power before work on!!
Good Luck
mai
Sep 18, 2014 | Whirlpool Dryers
Whirlpool Imperial Series Dryer is Not Drying But Has Heat
Make sure it's blowing air out the vent outside. But even though it's heating doesn't mean it's heating 100 percent so u might need a heating element. Not to expensive to buy and often not to hard to change, refer to owners Manuel or a computer on how to change it.
Feb 06, 2014 | Whirlpool Dryers
Whirlpool lgr8648lwo squeels when running no other problems.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 10, 2011 | Whirlpool LGR8648 Gas Dryer
My gas dryer heats a little for a minute sometimes, then turns cold for hours. Could this still be the igniter ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Dec 15, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer won't dry
Well lets talk about it a minute. The ignitor is ok because it does glow. The flame sensor is ok because the ignitor is working. The only other thing in the circuit is the solenoids. So what goes wrong? Those coils get hot and quit with age.7ecd66c.jpg Replace them and the dryer will come back to life.5dc4e80.jpg
Jun 28, 2010 | Whirlpool WGD5500S Dryer
Hi i have a whirlpool gas dryer LGR8648LWO and
If your ignitor (glow bar) is glowing that indicates the thermal fuse is okay.
With the symptoms you are describing it is acting more like an air flow issue than a component failure. Make sure your door seal is good, your venting is connected properly and try it again. I would not install the thermal fuse.
Apr 23, 2010 | Whirlpool Dryers
Whirlpool gas dryer heats then stops
you will want to do two things
first check you vent exhaust even a small clogg here can be detrimental
then if thats clear
repalcce the coils on the top of the gas valve
they are probaly weakening
they are called the boost and assit
or hold and assit
they sit ontop of the gas valve
Oct 13, 2009 | Kenmore 63942 Dryer
Whirlpool dryer won't dry
If your dryer spins and heats properly and the clothes don't dry, then very simply put, the moist air is not being taken away. If your drying temp is adequate, then the problem is with the exhaust. Go to where the air is being exhausted outside your home, if working properly, when you put your hand on the air coming out, it should get damp very quickly. And ALWAYS clean the lint trap after every load!!!!
Jun 21, 2009 | Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
