Question about Coates Spa Heater 5.5 Kw Ct12406st
I have a new coates heater and it takes 3 hours to heat my spa up
The old one took half that time whats the problem thank you
    Top Expert:
  • Coates Master
  • 7,200 Answers
Sounds like unit wired for 220 and 120 volts coming in
Posted on Dec 05, 2017
  • 125 Answers
Make sure the water flow is the same and the size of the heaters are the same. it sounds like the new one might not be the same kw.
there really isn't a solution to the heating not being the same if you have good water flow and the kw is the same as the old one.
Posted on Feb 26, 2009
How long should a 2007 eclipse spa take to heat up??
Usually spas heat approx 5 degrees an hour. If its been a day or so and your water isn't up to heat, you probably need a new heating element in your spa. Check the voltage at your heating element, and on your topside there is usually a heat indicator light that should be lit. If it has correct voltage at heater and the indicator light is lit, heater burned up. If you have incorrect voltage at heater check fuses for a possible blown fuse and see which pump it goes to, that could be your problem.
Mar 09, 2014 | Pool & Spa
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Ihave a 175000 btu Lite 2 Jandy Pool Heater model # LD175P. It takes approx 3 hrs to go from 48 degrees to 100 . Why so long?The spa is 7ft in diameter and normal spa depth.Should I have a more btu heater?...
That seems to be a pretty good heating rate. You're talking about 52 degrees in 3 hours. If you want quicker heating, you will need a higher output heater.
Gary
Jan 06, 2011 | Jandy Pool & Spa
Sta Rite SR400NA heater is about 3 yrs old. started once this spring and ran for a couple hours to heat pool slightly. 3 months later and trying to start it up and it will not do anything. read out says...
This is a common problem and easy to fix. Your temp sensor screws into the front side of the water manifold. You will just get a new one and swap it out. Your book will show you just where it is, but it's the size of a 1/2" plug on the top front of the manifold when you take the cover off the heater. Good luck.
Sep 19, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
My pool heater exchange is leaking. Is it worthwhile replacing this part $ 699.00 plus labor ? The unit is 4 years old. Can the old part be welded or sodered?
Along with the exchanger you will need header gaskets, manifold gaskets, Pressure switch and tube, igniter or pilot and maybe a temp sensor. I count on all of these when I do an exchanger, total cost about $300.00 Now your over a grand. Labor about two to three hundred, if nothing goes wrong, and hopefully it all get's done right. Now your up over half of a new one and 90 days on parts. I know I make money at this but I make money at rebuilding heaters also. I usually try to get people to go towards the new heater.
Then take a course in pool and spa chemistry. 99.9% of the time this is the cause of a bad exchanger and that is what hurts the other components at the same time.
Sep 09, 2010 | Pentair Minimax NT Heater
PLEASE HELP.....cant not get Batizime pool to heat up.
something is wrong with the voltage it should be 240 when you test the heater terminals, i think the heater relay isnt making a good contact. but i would check for 240 at the main panel and chase the wiring to find the voltage drop.
Apr 02, 2010 | Hayward Comfort Zone Electric Spa Heater...
Coates Spa Heater 5.5 Kw Ct12406st Logo
104 people viewed this question
Top Coates Pool & Spa Experts
john h
Michael Prior
Michael Prior
David Spradling
David Spradling
Are you a Coates Pool and Spa Expert? Answer questions, earn points and help others
