Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Leaking washer drain pump
Water appears to be leaking from drain pump in front. Is this common on Whirlpool Washers? Model GST9679PWZ only 3 yrs old. What holds the pump on other than the clips on each side?
  • Whirlpool Master
  • 3,361 Answers
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Posted on Feb 22, 2009
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
I have a GHW9100LQ front loading Whirlpool Duet washer that is 7 years old. It has recently been displaying error code F02. Today water leaked onto my floor. I read the suggestions on cleaning the drain...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Whirlpool GHW9100L Front Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer leaking water as soon as water starts into the tub.Washer only 3 years old
If you have a leak, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect your washer for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
NOTE: For future reference, if you would like to a have a complete repair manual for this model washer, Repairclinic.com has a one available for Whirlpool manufactured direct-drive washers (includes Roper) for about $20. The item number is 1170635.
Jan 27, 2010 | Washing Machines
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water pours out from washer underneath
The most common leak for those washers is from the drain pump a really easy and inexpensive repair. It is located underneath toward the front. To diagnose turn on water to tub fill 1/4 the way, pull out machine about 2 feet, tilt backward,you can use a mirror, I just poke my head under. is should be clearly evident where the leak is. The tools to change the pump it requires a screwdriver and pliers. There are two clips and to hose clamps,remove and replace in reverse order.
Mar 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
