Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Not enough hot water, has to do with a shower valve
Ok, I just installed a 50 ga LP hot water tank and I still don't have enough hot water for 1 person to take a 8 min shower and at the end of the shower cold is turned completely off and only hot know is on. I believe it has to do with a newly installed shower valve. If I go to the shower valve and turn cold water on, it runs fine. If I turn hot water on it runs fine. If I go to the hot water tank and turn hot supply off to the house and go back to shower and turn the hot water on it is dry if I turn cold water on it just barely trickles out. The valve is a single handle moen turns counter clockwise starts on cold and turns to hot.
  • 547 Answers
Take off handle (screw under cap) there is a plastic peice behind for ajustment if you move it one way it allows more if you move the other way less contact me if you have problems thank you for useing fixya please rate me
Posted on Feb 21, 2009
    Problem Solver:
  • 9 Answers
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
It's doubtful your water heater unit is the problem. There is simply no reason for it to only work on sinks unless some how the pipe size was drastically reduced coming out of the unit so sinks got plenty of hot water but the shower does not. Take a second look at the installation. The pipe should not be less than 1/2" coming out. If that's OK then consider a clog or valve problem.
May 18, 2015 | Titan SCR2 N-120 - 11.8 KW Tankless Water...
Does not supply enough hot water
I bet you don't drain your tank every year. It accumulates something a little like sand . it may have been low enough to "suck" up some of this trash into the hot water lines and then to your valve and shower head. I would start with the head itself a good long soak in vinegar. If you have a spare shower head or hand shower head, I would let it sit for a week. While you have the "tempory" head installed, you can find out if the valve has been affected. Hopefully not. But if it is still slow flow, the trash may have accumulated in the valve. If that is what it apears and you have been considering a new valve now is the time. You may be able to flush it out with a direct connected garden hose. A "reverse flush would be the first try.
Mar 08, 2015 | Home
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
Sirrus 1600 power shower
He may have put the mixing valve in backwards. This is very easy to do because it will let some warm water through and at least enough to trick the installer that it had hot water when tryin it out. Also is the shut off valve opened completely? Did he by chance close off the water heater valve also or tank not on just still warm? If other areas are normal you know it's at that one valve and my guess would be the actual valve body or shut off issue. There is also the chance of a faulty valve, damage from install, got to hot if soldered with valve in body and was damaged, debris in valve from pipes. But start there and verify that you have hot and cold to the valve, then if you do shut off system and try flipping the valve around.
Oct 22, 2017 | Home
Vanguard 50 gallon electric hot water heater only enough water for about 2/3 of a shower. Used to get enough for 4 showers. Had elements and thermastat replaced. Circuit breaker checked ok. No leaks -...
Replace overflow valve to end the drip.
If tank type water heater has some hot water, then upper element is receiving 240V and electric circuit can be eliminated as suspect.
Lower element or shorted wire to lower part of tank or upper thermostat not wired correctly are next suspects. If plumber replaced the parts the wiring will be correct, but he may not have checked for shorted wire.
If the elements were replaced but sediment was not cleaned out of tank, then that can also cause the problem you describe: the new lower element is shorted out because its stuck in the sediment or no water is circulating around the new element.
Open following links for details how to test and clean tank and test elements:
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Rheem Water Heaters
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
Burner will not increase when second faucet is turned on
Turn of the hot water valve and turn on a hot water tap in the house. If You have water flow, then you have a problem with a faucet (usually a shower valve). Go to the shower valve and see if you hear water running. If so that is likely the problem. Otherwise there is not enough gas to fire the unit that far and it will fail out. Check the manual most people install these units wrong. If you install it to code then you did it right. If you install it to the manufacturer's specs, you installed it to code and it is right. Then the only adjustment is with a Calibrated CO2 analyzer (instructions in the manual).
Apr 02, 2010 | Bosch AquaStar 250SXO-LP-RE...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
978 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
