Question about Akai LCT2662 Television
LCT 2662 after caps replaced I loose backlight.
I replaced all the caps my TV turned on with sound and picture after about 15 seconds I loose picture/backlite but the sound stays on.I found the 10 ohm.resistor near the LED open so I replaced it and now the red led is fine.(This is not a 2 color led no green on power up)
  • 139 Answers
Make sure the caps you installed are the exact replacements. Changing voltage capacity or timing will cause the circuit to fail.
Posted on Mar 06, 2009
  • Larry Oct 21, 2017
    What was the problem with the set before you changed the caps? Actually you can increase the voltage ratings of the new capacitors (within reason) as long as there is room to get them in, as the larger the voltage ratings the larger the caps get but the MFD should be the same.
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
May 07, 2011 | Televison & Video
When tv is turned on we have picture for about 10-15 seconds then it goes black but we still have sound
Sounds like the backlight power supply is shutting down and not providing the backlight needed to view the picture..this is a very common problem with flat panels as the components used are running at high speed and elevated temperatures.
Dec 16, 2010 | Televison & Video
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | RCA L32HD32D 32 in. LCD HDTV
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Aug 13, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Akai Model LCT 2662 problem
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Jun 03, 2008 | Akai LCT2662 Television
I have the same problem with my Akia LCT 2662 Television
Did you fix this yet?Please let me know.Thank You very much!
Tyler
May 01, 2008 | Akai LCT2662 Television
Akai LCT2662 Television Logo
117 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
