Question about Cooktops
Wolf cooktop burner ignitor keeps sparking after lighting
This is an intermittent problem. I have cleaned the ignitor with grit cloth to make sure it is clean. could this be an ignitor module problem? if so, How do I take apart the cooktop to get to the module?
    President:
  • 2,976 Answers
The ignitor will keep sparking until you turn it past the light setting. If it keeps sparking even after you set the flame for something other than light, you have a controller problem. The controller is located behind the knob, inside the top of the stove. If it doesn't light, take off the grate and clean all of the gas holes with a pin or toothpick.
Posted on Feb 21, 2009
  • 15,935 Answers
The problem seems to be with the switch itself sticking. There is a spring return inside, and if it got gummed up or broken, it will not release the igniter contact inside.
Replacing the igniter switch will solve your problem.
    President:
  • 2,110 Answers
I also found after cleaning this happened to me and we unplugged the whole unit for a bit and it "reset". It stopped. I am sure you alreadytried this but thought i should at least mention it in case you haven't.
    Genius:
  • 1,550 Answers
First off all provide model details .
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cleaned gas cooktop and spark ignitor started sparking on its own
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 07, 2010 | Whirlpool SCS3014LS Gas Cooktop
My ignition will not stop clicking
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
The electronic ignitors on my cooktop won't shut off. what's up?
1) Clean your ignitors & Burner with a dry cloth and see if it works.
2) You need to have proper Ground in your electirc connection. If there is no/ Poor ground than the unit will keep igniting even after the flame is developed.
if none of the above helps than check all the ignitor cable there may be a cut / leak in the cable causing spark / ignition in the middle of the cable where there is a cut.
Oct 10, 2009 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
One ignitor keeps clicking after burner is lit.
clean the bottom of the knob by using vaccium,remove the knob then clean it.return the knob in possition how u remove.
tnx gerbee
Jun 28, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cooktops Logo
405 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Cooktop Expert? Answer questions, earn points and help others
