Question about Dell Microsoft Windows XP Home Edition
My laptop only turns on when it is plugged in but in about 5 seconds it will shut off.
  • 67 Answers
Do you keep it on a couch or a soft surface? Make sure the vents are not blocked by anything. It'll shut down if it overheats. If that's not the case, listen to the fan motor make sure it is working and cooling down your CPU. The last thing is your battery, It might be fried and overheating. You may want to remove the battery and run it with only power adapter to see if it stays on. Please let me know how it goes. Good luck :)
Posted on Feb 21, 2009
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Jan 01, 2013 | Computers & Internet
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
When I went to shut it down it had a few programs to shut down. I waited a few minutes then closed the lid down. It is now flashing on the first light symbol on the corner and when you open it up it turns...
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
Apr 22, 2011 | Compaq Presario CQ60-212US Notebook
The power lights on the lap top are blinking every 5 seconds and the screen is blank
lights blinking means your laptop is restarting after every 5 seconds. Your lappy might have gpu( graphics processing unit ) dry solder connection problem. I would get it looked at because it could also be a heat problem
Mar 01, 2011 | HP Pavilion dv9700t Notebook PC
White screen, won't play or power down
Mine does this when I plug it into my computer to charge and then the laptop is closed or the computer hibernates. I simply slide the power switch up to the ON position all the way and hold it there for at least fifteen seconds before releasing it. It then turns off. I allow 5 seconds and it turns on as ususal, no problem.
Apr 11, 2010 | SanDisk Sansa Fuze MP3 Player
My Toshiba A215 is frozen. The power button does not turn off. Cntrl/alt/del does nothing Mouse and claock are frozen as well. How do I fix? I was trying to download video files to ext hard drive. Window...
hello, press down on power button and hold it for about 10-15 seconds and it should shut-off, wait for about 5 seconds before turning it back on. If for some reason holding down power button doesn't shut it off, then simple unplug the power from the laptop and then flip the laptop upside down and locate the battery eject lever(little slider switch to kick out the battery) slide it to the unlock position and remove battery. Once again wait for about 5 seconds and plug the battery back in and then the power adapter and power on your laptop.
Tip: try copying few files at a time to get a better success rate and avoid any failures.
I hope this helps.
Regards & happy holidays.
Amar Sondhi
Dec 24, 2009 | Toshiba Satellite A215-S5822 Laptop
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Computers & Internet Logo
Alun Cox
