Question about Kenmore 22422 Top Load Washer
Washer will not agitate
After washer fills up there is a loud humming sound and will not agitate
  • 188 Answers
There is either something stuck in the drain pump or the motor is defective. The drain pump is connected to the front of the motor, if you remove see if the motor works without it. If it does work, check to see if there is something stuck inside the drain pump or if it is seized.
Posted on Feb 21, 2009
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
WASHER HUMMS BUT DOESN'T AGITATE
this sound i think come from motor so since there is no rotation the belt need to fit again or replaced by agood one,
g b y
Jul 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
My machine fill up but will not agitate, Whats wrong with it?
The humming sound you are hearing is the water valve either trying to open and can't or your water is shut off at the valve. Might want to check one final thing if either of the two scenarios above.....remove the washer hoses from the back of your machine and check to see if the screens inside the washer water valve are blocked. Good Luck! If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore 22422 Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Robert Rankin
