Question about Marantz Televison & Video
I need to remove my marantz pd4293d plasma from the wall. I am supposed to use an allen wrench to release it from the wall mount but I do not know where the allen screws are located.
  • 479 Answers
To remove your Plasma from the wall you will find the details with pictures on http://tinyurl.com/ao8zo8.
So please check it carefully and proceed.
Posted on Feb 21, 2009
  • Gyanendra Kumar Feb 21, 2009
    when you will open the page please scroll down and you will be getting different links where rear view and install will also be there.
    Brigadier General:
  • 3,614 Answers
Hi there.
may i know if you have a clear view at the back of the TV.?
Key wont turn ignition. ignition tumbler is broke, car is stuck in park in the middle of the street.
You really need a locksmith to sort this out.It is tricky to remove the lock unless you know exactly where to drill.
Jun 19, 2011 | 2001 Chevrolet Tahoe
Master Lock 34AT trailer coupler lock. key turns tumbler 90 degrees, but lock wont remove. I don't know if i'm supposed to use another tool (like allen wrench) for pinhole in bottom. Is there...
Instructions:
1. Insert key in cylinder and turn to right.
2. Slide trailer lock over side flanges of coupler as far as it will go.
3. Insert allen wrench (or screw driver) into opening at bottom of lock and turn it to right until hardened set screw is tight against inside of coupler. Remove wrench.
4. Turn key to left and withdraw it. Opening for wrench is now blocked.
(To remove lock, merely reverse above steps.)
Jun 12, 2011 | Master Lock 34AT Trailer Coupler Lock
Rearview mirror bracket won't release from mirror; has some sort of release clip accessable via small hole?
There is a small allen head set screw in the bracket. You will need a proper size allen wrench to loosen the screw, then the mirror should slide off the windshield mounted bracket.
Hope this helps!
May 10, 2011 | 1992 Ford Aerostar Extended
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
How do you install the blade in the craftsman recipricating saw model 320
You need a allen wrench to remove the blade and to reinsall it look at the base of the blade and you will see an allen wrench. If there is no allen wrench then you must pull down on the clap assembly to release the blade. If you still can't figure it out here is sears web site where you can get help for it if you need a picuter.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128394&sid=PSx20071217x00001a
Sep 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
How does one remove the belt tensioner off a 2001 honda passport?
14 or 15mm socket to release tension. Use socket with leverage bar push/pull towards driver side. Will notice tension releasing, pull belt. Use 5/16 allen wrench for bolt in center, 12 mm socket for mounting bolt. Remove bolts, remove tensioner.
Feb 13, 2009 | 2001 Honda Passport
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Marantz Televison & Video Experts
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
