Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Scan with feeder, cuts off the bottom of the document
If I use the feeder to scan a document to PDF the bottom of the scanned document is cut off.
My HP software is up to date. I use a mac with OSX 10.4
  • HP Master
  • 990 Answers
Hello sir; You may use rubbing alcohol to clean up allthe rollers at document feed unit, it will take care the problem.
Posted on Mar 02, 2009
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
How do i scan a legal size document on hp officejet 6830
You will need to use the automatic document feeder and there should be an option in the scanner software settings to tell it you are scanning a legal document.
Document feeder is not scanning the document but brings up a former scan
That is not possible. most likely is your PC not refreshing ? or you need to uninstall and reinstall the software
Mar 22, 2014 | Brother Any 4 Ink Mfc-5490cn Mfc5490cn...
I need to scan documents in jpg format. I notice there is an option to choose tif/jpg but I don't seem to be able to choose the jpg option it just keeps choosing tif. How can I scan in...
Everyone above has cut and pasted from the Ricoh manual, which as any tech will tell you is worthless. There is some other setting that must be set to force the "TIFF/JPG" to toggle - hence why no one has figured it out.
Jun 17, 2011 | Ricoh Office Equipment & Supplies
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Cutting off when i scan threw the adf feeder
Check if the paper size selected is same as that of the paper fed in. Clean the sensor in the ADF and remove if any scrap of paper is stuck.
S. Mohan
Oct 08, 2009 | Fujitsu fi-4750C Flatbed Scanner
Can not scan legal documents
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
154 people viewed this question
Ben Johnson
