Question about Cyber Acoustics Accent S-3022 Computer Speakers
Lost ac adapter and dont know how to connect - Cyber Acoustics Accent S-3022 Computer Speakers
  • 265 Answers
just use some other adaptor round the house that will fit.
or you can buy a multi adaptor ac for it
thanks
Posted on Feb 21, 2009
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
See I just bought Xenyx Q502USB from amazon. I connected it with the AC Adapter for a second. lights in the mixer were lit but after a sec lights were gone. And now when I connect it with AC adapter
There are items like this that fail right out of the box. You can test the adapter with a meter to see if it is the part that failed. If it is you can get another adapter like a universal one or you can get a replacement. If the adapter is fine you have to send it back.
Oct 10, 2014 | Behringer XENYX Q502USB 5-Input/2-Bus...
Lost my AC adapter, and dont know what the adapter specs are so as to get a new one
You'll need a 12V, 1.5 Amp power supply. Center pin is positive (+).
Something like this should do.
Nov 17, 2009 | Western Digital My Book Essential 1TB...
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
I lost the AC adaptor for my conair BMS10M massage cushion
yeah ! Just Go on & search for the compatible AC adapter in the market and dont forgrt to carry ur AC along with you to test the adaptor for wether it is compatible for your AC.
Or else throw your old conair AC and buy a new one !
Jan 11, 2009 | Conair Weight Watchers WW-87 Body Fat...
Ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
Cyber Acoustics Accent S-3022 Computer Speakers Logo
169 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
