Question about Singer 5050 Mechanical Sewing Machine
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
    Problem Solver:
  • 6 Answers
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Posted on Feb 21, 2009
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Our simple 3116 won't zigzag stitch,the needle is off to the right and will not do any other stitches. Help!!
It won't do straight stitch?
Take the needle out... see if it is moving the fabric when you press on the presser foot. If it is not, then you need to raise the feet (it's under the accessory box/table face. If it does move the fabric. Make sure your machine is set to Zig Zag. again without needle... sew. Does the needle bar move? change to straight stitch, does the needle bar move? If it does I think you have the wrong size needle. If it does not, I'm afraid your plastic machine has broken... take it in for repair.
Oct 04, 2014 | Singer 3116 Simple
Bobbin thread is making big loops ,not tight stiches.
Sounds like your bobbin case tension has loosened. First, take a piece of scrap fabric and sew a line of zigzag and another line of straight stitches. If the top of the zigzag stitching looks like chicken tracks, but the bottom looks normal, the top is tighter than the bottom. Take the bobbin case out and locate two screws on the side. One is a Phillips--DO NOT TOUCH IT--the second is a straight-slot--that is the one you want. Remember, lefty loosey, righty tighty! In your case, you wand to turn it 1/4 turn to the right to tighten, and then put it back and test again. You should see SOME improvement--it many not correct it entirely but you'll know you're on the right track. Keep at it, doing ONLY 1/4 turn and then testing, until it's in balance again.
Aug 04, 2014 | Singer 2263 Mechanical Sewing Machine
Top stich perfict but bottom stich too loose on vivo singer machine 1004
Your bobbin tension needs adjusting, and although it is not hard to do and doesn't require that you take the machine apart, you MUST do it systematically. If you don't, you'll make things worse.
First, download the user's manual from the Singer site if you don't have one. On page 20, you'll see a discussion regarding tensions, and what improper tension looks like. Tension is a balance between the top and bobbin.
Then, using scrap fabric, set your top tension on Auto and make sure your needle is all the way up in the clamp. Run a line of straight stitches, and next to it, run a line of zigzag stitches, maybe four inches, and examine it. The illustration on that page will show you what your straight stitches SHOULD look like. If your zigzag stitches show one side that looks like "chicken tracks" but the other side looks like it should, the chicken tracks side is too tight. In your case, if the bobbin is too loose, the top will look like chicken tracks. It helps a lot to use two different thread colors, as well as a third for the fabric.
To adjust the bobbin tension, you will need a tiny straight blade screwdriver. If you have an indication that the bobbin side stitches are too loose, take the bobbin case out of the machine and locate two screws on the side. One is a Phillips--don't touch it. The one on the left of the Phillips is a straight-slot screw--that's the one you want. The saying is "lefty loosey, righty tighty." If your test indicates the bobbin tension is indeed too loose (which can happen over time), you need to tighten it by turning the screw 1/4 (ONLY) turn to the right (righty-tighty). Test again. You should see at least some improvement to indicate you're on the right track, and repeat--turning ONLY 1/4 turn--until your top and bottom tension are balanced. Don't forget to also test with a zigzag; I have adjusted bobbin tensions in the past that looked OK on the straight stitch, but the zigzag indicated I wasn't quite there yet.
Jun 25, 2014 | Singer 2638 Mechanical Sewing Machine
I cannot get tight tension on zigzag underneath stitch on my singer 3221
There are a couple of things to check. First, did you thread with the presser foot UP, so that proper tension is applied to the upper thread? Is your bobbin correctly inserted, and is your bobbin case inserted evenly and correctly? Review your user's manual--if you don't have it, you can download it free at the Singer website.
If you have done these things, you may need to adjust your bobbin tension. First, run a line of straight and then zigzag stitches on a scrap of fabric and take a look. It helps to have two different colors of thread, with the fabric a third color. If one side of the zigzag looks fine and the other side looks like "chicken tracks," the chicken tracks side is too tight. In other words, you need to determine whether your bobbin tension needs to be tighter or looser.
You'll need a very tiny straight-slot screwdriver. Remove the needle plate--there are two screws in it--and remove the bobbin and then the bobbin case. On the side, there are two tiny screws. One is a Phillips--leave that one alone. The other is a straight-screw, and that one regulates the bobbin tension. The rule is "righty-tighty, lefty-loosey." Only turn it 1/4 turn, then reinsert and test. If you're on the right track, you should see at least a LITTLE improvement. DON'T do any more than that--if you don't do this carefully and systematically, you'll make things worse instead of better!
Jun 10, 2014 | Singer 2263 Mechanical Sewing Machine
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
May 25, 2009 | Juki HZL-E61 Computerized Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
290 people viewed this question
Top Singer Sewing Machines Experts
mystery_soul
Level 1 Expert
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
