Question about Mitsubishi VS-50607 50" Rear Projection Television
I don't know how to get to the mirror and projection guns
I have a mitsubishi VS-50607 50". How to I get to the mirror and projection guns to clean them?
  • 2,920 Answers
The front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Posted on Feb 21, 2009
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
We have a Mitsubishi VS-50VA2 projection tv. The picture is very dim and the color is faded. Even after adjusting the brightness to the max, it is still dim. What do I need to do to fix this?
you need to clean the dust off lamps and the guns, if you don't know how. i can walk you thru it. but i would suggest having a repair shop do a full cleaning.
Jun 24, 2011 | Mitsubishi Televison & Video
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
You need to remove front screen of TV to clean the mirror or anything inside.
Check below exploded view of VS-50705 manual to have an idea...
Aug 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
What is the easiest and safest way to move the VS-60707? Does it just lift off the base? If so how?
I`m not so sure about Mitsi`s, But usually the Chassis comes out as one complete unit so that it can be removed for service and taken away back to the workshop. The philips ones, The whole top section (Screen & Mirror) used to come away as one piece and then the whole bottom section could be taken away for service. Have a play but DON`T TOUCH THE MIRROR, it is silvered on it`s face, is EXTREMELY EXPESIVE to replace and is VERY EASY TO DAMAGE with finger prints and cloths etc.
Apr 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi vs-50603 removing screen for cleaning
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Mar 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
How to remove the mirror casing
The mirror on this unit is fixed and there is not a method to drop the mirror.
Feb 23, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi Model No VS-5069
You will need to contact a glass place to cut a new mirror that has the reflection paint on the outside of the glass instead of what most mirrors have them painted on the opposite side . Good luck
Jan 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
