Question about Air Tools & Compressors
Jun air model 4-15 power light on humming but no motor cutting in. relays click to switch motor on but nothing happens,
  • 25 Answers
Output haft on motor may may have loosened or rod fell off.
Posted on Feb 25, 2009
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Oct 13, 2013 | Haier HSW02C
Lights flip up when car starts,never go's down
sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | 1981 Chevrolet Corvette
1981 c3 headlights flip out when car is started,but will go down
49de7c30-fce9-4e27-ae89-f6cfe5dc93d3.jpg Sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | Cars & Trucks
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
My cambell hausfeld , model WL650001AJ won`t come on . Have power to and through ths switch . Motor hooked direct to power and no start . Any thoughts ?
Check for a reset switch on the motor or air pump. They're usually located on the edge of the motor housing sometimes partially hidden by the air shroud around the air pump. It's usually a white button about the size of a pencil eraser with a two digit number in the middle of it. If it's sticking out of its housing push it in to reset it.
Oct 14, 2010 | Campbell Hausfeld 26 - Gallon Air...
Penguin RV air conditioner does not power on. Have 120 volts to the air conditioning unit. When I turn on power switch to unit nothing come on.
Check on the cut off relay connected to the compressor. Also check if the capacitor to the motor is faulty. You can test for power to the relay and the resistancce of the compressor motor coils to make sure that the motor is intact. if not one of the above is faulty.
replace and test.
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Blower motor hums but wont start
Check motor capacitor and try spinnig blade or wheel to see if spins freely if doesn't then the bearings are bad in motor and needs replaced
Apr 09, 2009 | Heating & Cooling
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Feb 28, 2006 | Panasonic SC-PM19 CD Shelf System
Air Tools & Compressors Logo
182 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
