Question about HP DesignJet 450c InkJet Printer
HP designjet 430, the data and media light come on at power up
After turning on the unit the data and media light come on. I can press a button and get the ready light to come on. If I try to load the roll paper it goes fine untill it trimes the sheet. Then it backout the paper and the media light flashes. I cleanded a lage amout of ink off the sensor on the carrage assembly. The service manual suggest replacing the carrage assembly after checking the trailing cable. HP support suggested the system board.
  • ltyndall286 Feb 23, 2009
    That's what I though but I did not want to tell our customer that untill I got other input into the problem
  • 53 Answers
The sad part unfortunatly is that the sensor on the carrage is below minimum specification. The only solution is to change the carrage as a unit P/N C4713-60039 and its going to be expensive. Normally the carrage belt would be replaced at the same time.
Dave
Posted on Feb 23, 2009
When you turn on my hp 430 desinejet printer the light comes on in the error group that says media
on this machine ( v old) if the drive belt has chewed then the plotter will not even come to ready instead it makes a few clunks and flashes lights - If this accurately describes your error then you will need the drive belt replacing, however this machine is now so old that getting hold of new unused parts is nothing short of a miracle Good luck with that one!
Feb 11, 2014 | HP DesignJet 430 InkJet Printer
MY designjet 430 all of a sudden is not printing straight, but is printing wiggly lines. Any ides on how to fix this?
You can try Print-Quality Plot test to diagnose the problem. Load paper, when ready light up, then press Form Feed and Media Source keys together. After print is done, unload paper.
This plot consists six tests. The third one is Vertical Line Straightness (VLS) test. You can read the HP 430 Service Manual page 6-7, 6-8 and 6-9. These articles will tell you how to correect the problem.
Sep 01, 2010 | HP DesignJet 430 InkJet Printer
Does the HP DesignJet 1050c plotter have a counter?
This data is printed out on the Service Configuration Print
  1. Load the plotter with media.
  2. When the device is 'Ready' scroll the menu to the Printer setup options and press Enter.
  3. Once in the 'Printer Setup options' menu, use the arrow keys to scroll to 'Utilities', and press Enter.
  4. In the Utilities menu, use the Arrow key to scroll to 'Test Prints' and press Enter.
  5. Use the arrow key to scroll to 'Service Config' and press Enter to print the Service Configuration Print.
You should find the data you are after under the heading of Maintenance on the printout
Good Luck!
Dec 07, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 430 wont accept media
This is the problem with the sensor. It tries to read the size of the paper, the sensor is on the side of the carriage assy(cartridges are installed on this assy). You can try cleaning this sensor or get it replaced or some times the service center will replace the carriage unit as a whole.
Dec 01, 2009 | HP Office Equipment & Supplies
HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
Media Rejection
edgie46,
I have some bad news for you. The media sensor is faulty. This sensor is not sold seperatly. The entire pen carrage (head) has to be replaced at quite a cost.
Your part number from an HP parts supplier is C4713-60039
Its strange that is a refurbished machine with a faulty carrage. Maybee you can claim under a warrenty
May 01, 2009 | HP DesignJet 430 InkJet Printer
Error lights
Lights are explained in the owners manual. Google HP 450 owners manual if you don't have yours. Various lights can be everything from change the ink to close the cover to Oh Oh, you're in trouble!
Sep 03, 2008 | HP DesignJet 450c InkJet Printer
Hp designjet 430 cartridge light on
make sure the contacts on the print cartridge and the carriage area where they go are clean. if cleaning the contacts doesn't help then the carriage and/or trailing cable will need replaced.
May 06, 2008 | HP DesignJet 430 InkJet Printer
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
HP DesignJet 450c InkJet Printer Logo
924 people viewed this question
Ben Johnson
