Question about Samsung RS2630SH Side by Side Refrigerator
I have a samsung 4 doors the noise from the motor is anbearable , otherwise everything works fine
    Problem Solver:
If it is occasional, 2-3 times a day, it's probably the condenser fan that everyone hates. It's easy to take out and replace. You can get some short term relief if you take it out, take off the fan, take out the motor and wd40 both end of the shaft. Either way make sure you put the fan back on the shaft all the way by tapping it lightly, it will slip on but it has to go on a bit further. the motor is easy to find on the parts sites
Posted on Feb 21, 2009
Samsung RS263tdbp fan making noise when closed and opened refrigerator doors
is there a build up of ice around it or is the fan blade bent and hitting something, otherwise u may have a bad motor in the fan going out
Jul 17, 2014 | Samsung RS263TDBP Side by Side...
Condenser fan noise
you should have warranty from the tech at least one month ,but it sounds like motor fan is giving up umplug your fridge take off back bottm part to expose the fan and condenser clean all the lint in the condenser vaccum is better ,turn fan with your finger it should be very loose ant turn freely if it stucks its the motor ,umplug the motor pull the fan with the plastic base out of its place,take off the screw on the fan,pull and twist it by hand,take off two or three screws that is holding the motor to de base, buy a newone ,a the apliances store or online for about 45.00 put back everything in reverse way.plug your fridge, enjoy!!! good luck
Apr 07, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My passenger side window on my 2005 taurus sel. will go down, but the motor doesnt make a noise, nor does the winow go up when i hit the down button on eather door.
Check the windows switch on driver side. Most of the time if driver side switch goes bad it effects everything to work properly. There's really no way to test the switch unless you have volt meter tester, switch are 40 bucks new and 10-15 used at juck yard. If your driver door switch working fine than check you regulator and motors. to get to it you will have to take the door apart and its painful and not easy task but if little mechanical incline with proper tolls, you do fine. Before you tear into the door, check or replace the door switch first, 99% of the time it solved the problems, assuming the window motor is working. hope that help..good luck!
Aug 07, 2009 | Ford Taurus Cars & Trucks
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
The driver's side window will NOT go down. All the other windows go down fine. The locks all work.
ford window motors are bad about burning out. if you can get the door panel off try tapping the motor with a hammer and see if it frees up. if it does, you know the motor needs to be replaced. otherwise the contacts on the switch may be dirty. check the fuse too, just in case.
May 30, 2009 | 2003 Ford Mustang
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
125 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
