Question about Dell 924 All-in-One InkJet Printer
How do I change the language to English on the printer
Printer is showing a forign language in the window.
  • Dell Master
  • 4,338 Answers
Power off the printer.
Press the up button and power simutaneously.
When the language settings appear, use the up/down arrow to find your language.
Then press menu to save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 21, 2009
Please somebody can teach me how to change language on biz hub c300. It is in chinese and i would like to change to english or portuguese. Thank you
On Control Panel-Touch Screen, Down right Side there is a tab to change the languages/Language Setting.
Even if it is Chinese or Portuguese language showing just click on the down right side button on touch screen, a new menu will appear. From there you can select your desired language.English-Chinese etc.
Mar 13, 2015 | Konica Minolta Bizhub C300 All-In-One...
My printer language has been changed accidentally, pls help me to change it to english language. send me how to change using the control panel.
Hi vivekchat18,
The instruction below will help you put back the display language you desire for your printer. You may use the procedure below to print out reports or to show messages on the all-in-one control panel. Here's how:
1.First you need to press MENU.
2.Then, select SYSTEM SET UP.
3.Afterward, select LANGUAGE.
4.Now, choose the language that you prefer. In your case, ENGLISH.
5.You have to SAVE your settings.
6.Finally, wait until your system automatically restarts.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | HP LaserJet 3050 All-In-One Printer
How do u change the language on the fax machine
Press the power button for 4 seconds. That will turn off the printer. Now, press and hold Start and Back button (looping arrow) while turning on the printer by pressing the power button again. Continue to hold the Start and Back buttons for approximately 20 seconds, then release them. That should reset the printer. Choose your preferred language and set time and date.
Jul 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
Change language Japanese to English Canon MP600 printer
when ur give the order of printing. it shows various options related to ur print on screen such as font style,paper type ...
in those u can find ur language setting.Just change it toENGLISH.
if it doesnt work then reinstall the printer setup & that time choose the ENGLISH language.
Jul 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
125settings for language back to English on LexmarkX
To change the language on the LCD screen of the X125 printer, please follow the steps given below:
1. With the printer power on, press the "Setup" button.
2. Then press the "Menu" button until "Set Language" shows on the screen.
3. Press the "Options" button until you see "English."
4. Press the "Start" button once and let us know the results.
Apr 11, 2009 | Lexmark X125 All-In-One InkJet Printer
How do i change the language?
I have Brother DCP-130C all in one Printer.
When I installed the software I chose English as the language, but when i am scanning & when i go into printing preferences it seems to be in German. I un-installed & re-installed but still not in English.
Any ideas how I can change the language to english please?
Mar 31, 2008 | Brother DCP 130C All-In-One InkJet Printer
Changing Language
I had the same problem with my Canon Smartbase MP730. Printer properties was in Portuguese, no matter how many times the driver was uninstalled and reinstalled.
By running Filemon from SysInternals I realized that when showing the printer properties files in the
C:\BJPrinter\CNMWINDOWS\Canon MP730 Printer\LanguageModules\0409\
folder were created. One of those files was CNMmhya.hlp. When clicking on it a Help-window with Portuguese text shows up - even though the code 0409 means English. This is a symptom of the problem. This file was copied from somewhere in the Windows folder.
To fix this annoying problem, the following worked for me:
-> Unplug the printer
-> Uninstall the driver
-> Rename the following folder with the portuguese language driver stuff which still remains, even after uninstallation of the driver:
C:\WINDOWS\system32\spool\drivers\w32x86\3
(if you cannot rename it, reboot and try again). You should first check that there are indeed portuguese help-files in this folder. To do that, click on one of the .hlp files. If they are not your problem could be a different one, but it could also be that the files are stored nearby in the file system.
-> Reinstall the driver with the language of your choice. This time there won't be Portuguese files blocking proper installation of your new files.
-> Replug the printer to finish the driver installation
Now you should have finally gotten rid of the Portuguese (which may seem Spanish or Italian to some) text in Printer related windows.
Jan 12, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Lexmarkx73
On the printer or on the program?
The program included can help you change the settings on the printer itself.
Go to the printer properties within Windows then to Printer preferences by right clicking on the Lexmark printer, look for language and set it to English. Press ok.
Dec 15, 2007 | Lexmark X73 All-In-One InkJet Printer
LANGUAGE
Alternately, just reinstall the software.
Oct 21, 2007 | Lexmark X73 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
147 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
