Question about Jenn-Air JCD2290HES Side by Side Refrigerator
GE Refrigerator No Ice or water from dispenser.
I have a GE Profile Side by Side Refrigerator. Model PSI23MGPC.
The water and ice dispenser do not dispense anything. The courtesy light comes on, but nothing comes out. When choosing Water, there is NO sound, at all. When choosing Ice, there is a sound of a chute opening and then closing after awhile. The Ice Maker makes Ice and the filter has just been replaced. Any ideas?
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
SOURCE: The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
Posted on May 04, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
  • 572 Answers
SOURCE: MY Jenn-Aire bottom freezer, with water dispenser
check water supply hose. if ok the check valve
Posted on Feb 08, 2010
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
578 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
