Question about HP PSC 2355 All-In-One InkJet Printer
Printer HP 2355 not running
Could you give me the script at the start menu to type in
so that I can check the printer to run. Right now inactive.
  • 447 Answers
Start + Control Panel + Printers + right click printer icon + use printer online.
Posted on Feb 21, 2009
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
My HP PSC 2355 says is "offline" and wont print anything
Click Start
Click Control Panel
Click Printers
Right-mouse click on your HP printer
Choose "go online".
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
PSC 2355 All-In-One InkJet Printer: MY HP PSC 2355 printer is printing slow...
Please perform the steps below and check
1. Right click on My Computer and go down to Properties.
My Computer is usually on your desktop or in the Windows Start menu. Click on the Advanced tab at the top of the screen.
2. Under the Performance section, click on Settings.
3. Click on the Advanced tab.
4. Under Processor scheduling click on Background Services. Click on Ok then Ok again.
If the issue still persists please get back to me with the Operating System of the computer
May 18, 2010 | HP PSC 2355 All-In-One InkJet Printer
After power failure my printer wont print
SOME TIME THE PRINTER IS NOT DETECTED ON THE NETWORK DUE TO SOME FIREWALL EXCEPTIONS
So we will try to overcome the problem before that lets delete all the entries of the printer so insert the Cd of the printer driver and then open the content and go to the UTIL folder of the CD and then open CCC and then Run the UNINSTALL_L3 file and wait for it to finish then restart the computer
NOW Press the Setup button on the all-in-one. Press the arrow buttons until Network displays and then press OK . The Network menu displays. Press the arrow buttons until Wireless Setup Wizard displays and then press OK . Follow the instructions in the Wireless Setup Wizard. enter the router password when it says connected to network then press ok and press the setup button again and go to network and then go to view network settings and print network config page
the page will print out look fot the ip address on that page now click on the start button and go to run and then type cmd and press enter and then in the black screen type Ping(give a space and then the ip address of the printer without these brackets) and press enter now if it says reply from destination and then gives sent 4 lost 0 recieved 4 that means the printer is on the network
Now run the priner driver and then install the printer through the network if still it says no printer has been detected then click on start and then run and then type services.msc in the window look for hp cue and hp device discovery (network ) both the services should say started and automatic if its stopped right click and start it
now retry if sill not detected then click start run and then type devmgmt.msc now in the window that will open go to view menu and select show hidden device and then in the list look for multifunction adaptor and then under it you will se the printer name right click on it and select enable now retry even if still you have a problem then rightclick on the multifunction adaptor and delete it and then retry it hope tis will surely work but still if you have problem just let us know
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
HP PSC 2355 all-in-one printer not scanning
You need to start the HP software that's installed on your PC.
In Win XP, go to Start menu, look down the list of installed programs, and click on HP Director to start it up. Your scanner should work now, either from the scan buttons on the printer, or from the scan options within HP Director.
Nov 11, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one printer
Can you turn on the printer normally? If you can't then you have a faulty power adaptor. If you can then it sounds like the connection between the computer and printer has been lost. Disconnect the printer and reconnect to another USB port. If this works then fine, if not then try another device in the same usb port to check wither the usb port is functioning. If it does, you have a faulty printer. You might be able to clear any probelms in the printer by performing a full reset.
Ppower up the printer and discconect the power supply while the printer is running. Hold the OK and Cancel buttons while reconnecting the power supply. When the printer switches off after 10-20 seconds, release the buttons, unplug the power and reinsert it. Turn on the printer and reun through the processes before plugging inth e USB. If it is still faulty, throw it away!!
Let me know what happens
Jun 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp printer will not effectively cancel print
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it runs out of paper,Paper Jam or Cartridge runs out of Ink or any other reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
120 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
